1985 928S 16x7 Manhole Rim question
will 16x7 928 manhole wheels fit a porsche 944?
they are 65mm B/S and 5x130 bolt pattern |
They are a perfect fit for 87- 90 944 cars. With spacers, they will fit an early 944 (83-86).
Good luck, George Beuselinck |
for an 83-86 944 do you need spacers in the front and rear?
what size spacers? |
Late cars are 52.3mm offset and early cars are 23.3mm offset. So a 29mm spacer would be needed.
M |
All Spooled Up
What would happen if ya just shlapped em on?
>gray 89 951S - K27/8, MAF, 3" intake, 3" exhaust w/separate waste pipe, 55# inj, late cam; >red 87 924S - chip, K&N, punched-out cat&muffler >black 80 924 - (sold) >maroon 77 924 - auto (sold) |
^they would look silly and your wheel track will be narrower than it should be. you might also have steering issues up front.
'87 911 GP White "casper" '97 Esprit V8 "flat eric" '97 993 Speed Yellow "tbd" |
