Porsche 924's Avatar
Ride height???
Hi I would like to know hat determines the ride height in the rear end of a 924s. Cuz I'm baffled, I can't find any springs at all.
Old 11-14-2010, 08:41 AM
ernie9944's Avatar
There is no spring on a 924S ,ride height ajustement is either achieve by re-indexing the torsion bars (witch I don't believe you want to get into) or adjust it at the cambers plates,this will give you an ajustement of approx 3/4" up or down.If you want to do it this way, I suggest you get somebody that has done this before to help you out.Migth look easy to do but it's not believe me
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Old 11-14-2010, 10:03 AM
KEV951's Avatar
measure from the center of the hubcap to the fender straight up, should be around 25"-26" stock or so, maybe a little more.
Old 11-14-2010, 11:07 AM
Soooo...damn...that sound hard...but..then what makes the car spring back up if there r no springs???
Old 11-16-2010, 07:36 PM
flash968's Avatar
torsion bars
and i doubt that the car sits at 25-26 from the center of the cap to the fender - that sounds more like fender to ground
Old 11-16-2010, 07:53 PM
ernie9944's Avatar
____ Torsion bar is number 24 in the diagram.As you can see Porsche rear suspension are not all that simple to start with,but also one of the reason they hold the road so good.
Originally Posted by flash968 View Post
torsion bars
+1 this is pretty standard 25-26 stock heigth ,LOL_ Kev_ must be getting ready for the snow if he raise her that higth
Old 11-16-2010, 08:28 PM
KEV951's Avatar
fender to the ground !! OOOOOOOOOOOOOOPs!
Old 11-16-2010, 11:53 PM
I'll have to measure to be sure. But my car is sitting about 25 to the fenders on all four corners. I wouldn't suggest going much lower than that, unless you like replacing oil pans and front lips...
I wouldn't consider reindexing torsion bars to get it lower again either.... Thats a bloody nightmare.
Old 11-17-2010, 07:01 AM
KEV951's Avatar
25" is good for street, 24" is great for racing or track
Old 11-17-2010, 10:24 AM
fiat22turbo's Avatar
Torsion bar = torsion spring
It is just a different style of spring. Works well as it provides better packaging and a lower center of gravity.
Technically an anti-sway bar is a torsion spring.
Basically, the spring is twisted instead of being compressed like in a "standard" coil spring (which the coils are technically twisted as force is applied)
Old 11-17-2010, 10:26 AM
