MSD 6 Controller, 9810 Tach adapter and Diode
Did my MSD 6BTM ignition Controller upgrade last weekend and it worked great on the first attempt. Wired in the 9810 Tach adapter and included the rectifier diode as recommended and mounted it all on a custom fabricated aluminum mount. The car fired up on the first key crank, runs smother and Tachometer works fine. This is the setup needed for uninterupted performance with the MSD 6XXX units. Getting ready for boost next year with the BTM unit.
Just wanted to share the news... :eek:My new engine upgrades work like a champ. Hope this post will be helpful. Later http://forums.pelicanparts.com/uploa...1289352857.jpg http://forums.pelicanparts.com/uploa...1289352895.jpg |
Is this supposed to give you more power or what?
Excellent!!!
Also, there's a treat here for others looking to install an MSD/Mallory box. Quote:
These types of systems work great with aftermarket chips that run richer, MAF conversions and of course: turbo cars. |
Highly recommend this upgrade for Forced induction Vehicles and conversions.
The BTM manually retard boost with up to +15 more Degrees. More Torque in low to mids and smother Engine Idle. More Air + more Fuel + More Spark Energy = More Efficiency/Safety & Power Capability Hope this post was helpful... Later. |
| All times are GMT -8. The time now is 07:32 PM. |
