Porsche 944S Club Sport
guru944's Avatar
Send a message via AIM to guru944
Thumbs up MSD 6 Controller, 9810 Tach adapter and Diode
Did my MSD 6BTM ignition Controller upgrade last weekend and it worked great on the first attempt. Wired in the 9810 Tach adapter and included the rectifier diode as recommended and mounted it all on a custom fabricated aluminum mount. The car fired up on the first key crank, runs smother and Tachometer works fine. This is the setup needed for uninterupted performance with the MSD 6XXX units. Getting ready for boost next year with the BTM unit.
Just wanted to share the news...
My new engine upgrades work like a champ.
Hope this post will be helpful.
Later
Guru944
2006 955 Cayenne S Titanium Series - Marine Blue, 1987 Porsche 944S Club Sport.
1987 Buick Turbo-T Lightweight "Great White", +500HP, TA49 Turbo.
http://www.blackbirdmotorsports.com, 944/951/968, 911 and 955/957 Performance Solutions.
Thank you Lord, for your Loving Kindness, Tender Mercy, and Grace. Only You are Faithful.
Old 11-09-2010, 05:36 PM
Is this supposed to give you more power or what?
Old 11-09-2010, 07:17 PM
Burn the fire.
Brando's Avatar
Excellent!!!
Also, there's a treat here for others looking to install an MSD/Mallory box.
MSD units are Multiple Spark Discharge units. They are high-output CDI ignition systems. 1-3000 RPMS they deliver 4 sparks per ignition per cylinder, then 3001-???? they deliver a longer, stronger burst of energy. Best to use with a recommended high-output coil. It provides for a more complete burn.
These types of systems work great with aftermarket chips that run richer, MAF conversions and of course: turbo cars.
[x] Working | [_] Broken: 2017 Victory Octane
[x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi
"Drive it like you stole it."
Old 11-09-2010, 07:18 PM
guru944's Avatar
Highly recommend this upgrade for Forced induction Vehicles and conversions.
The BTM manually retard boost with up to +15 more Degrees. More Torque in low to mids and smother Engine Idle.
More Air + more Fuel + More Spark Energy = More Efficiency/Safety & Power Capability
Hope this post was helpful...
Later.
Guru944
Old 12-01-2010, 03:30 PM
