ernie9944's Avatar
Oil filter magnet
Lately I've receive some PM asking me about the (yellow thing ),siting under my PS reservoir on my 968 & ex 944.It's call a FILTRO tm a very very stong & well design oil fiter magnet, in fact if you lay it flat on a piece of steel ,there is no way you'll pry it off by hand.This one will catch all unwanted particles traveling in your oil & keep it on top of your filter.Since we can't use the wrap around type on our car it will fit perfectly on top of your filter.I'm no good at linking but for those who want more infos about it here it is.Google Canadian Tire Filtro tm oil filter magnet,then once on the page look for Filter Max.Prize is approx $30.00 CDN + $8.00 shiping to US.
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Old 11-27-2010, 10:12 AM
flash968's Avatar
2 schools of thought on filter magnets:
1. the magnet will catch the metal fragments and keep them from getting into your system
2. the magnet will pass a magnetic charge to the ferrous particles, which will then stick to anything ferrous
on the presumption that #1 is 100% effective, this sounds great - if not, which is more likely the case, #2 is potentially pretty ugly
since engine bearings are non-ferrous, the block and head is aluminum, and the pistons and rods are aluminum, that material would not get caught by the magnet anyway, so i don't really see much of an advantage, and i only see the potential of scenario #2 coming into play and letting particles get stuck to what is ferrous (the crankshaft)
while i have no definitive evidence of either scenario prevailing, i have seen magnetically charged particles on a crankshaft twice, and only on an engine that used a magnet each time
Old 11-27-2010, 11:12 AM
Yep, Just another Gimmick to get your hard earned dollar away from you just like that so called gas saver.
Cheers,
Larry
Retired USAF and Civil Service,
1985.5 NA Graphite Metallic, A never ending work in progress,
1992 968 Horizon Blue Cab "New Toy"
Old 11-27-2010, 09:02 PM
smokin_944's Avatar
Larry, I believe you are correct again...
1984 - 944 Black / Wilwood/Brembo brakes / fresh M-474 suspension / Welt 250 lb fronts / 28 mm solid T-bars / M030 bars w Racer's Edge hardware/MSDS headers
Old 11-28-2010, 03:49 PM
