No Injector Pulse
I have a 1986 944. I have spark and the fuel pump appears to be working but the car will not start. I do not hear the injectors firing when I listen with a stethoscope. Pulled the DME relay and did the 3 wire jumper and same issue. What to do next. PS. The guy I got the car from said he removed the security system. Is there something he might have messed up that would allow spark and fuel but no injector pluse ?
Old 11-14-2010, 06:19 PM
What would Darth Vader do
Gordon Rankin's Avatar
Send a message via Yahoo to Gordon Rankin
Does the engine itself turn over?
1983 944 (2002 to now)
3-924's (Sold)
1967-912 (Traded)
NEVER put a used water pump in your car...
Old 11-14-2010, 08:08 PM
jim brown
there's a procedure to bypass the alarm system on clarks-garage.com, you can try that to see if the removal by the p.o. is the problem. I unhooked mine and did the bypass and it worked fine good luck!!
Old 11-15-2010, 03:32 PM
I am told that the alarm that was removed was an aftermarket alarm. There is no sign of a plug in the passanger foot well by the DME computer. The Car turns over with the switch as normal. Has fuel and spark but the injectors are not firing.
Old 11-15-2010, 05:05 PM
S ECU Repair's Avatar
The Trigger to the Coil and Injectors are driven by the same signal that comes from the reference sensors , if you have checked both of this sensors and they tested good , the next thing you need to do is to verify if you have 12 V to one side of the injector harness .
If you do ,make 100% sure there is no alarm system connected to the harness .
Here is a chart for testing the Motronic 35 Pin units :
Make sure some points of testing will only affect drive-ability and not a starting issue ,most important points to check are 12v supply , grounds and resistance values from Crankshaft sensors.
If everything seems to be fine after the check up we can offer you a free testing for your DME.
Best Regards
ECU Doctors Team .
Specialized ECU Repair
Porsche Bosch Motronic DME Specialists
Free DME Testing for Pelican Parts Members
www.ECUdoctors.com
1-800-328-1425
Old 11-16-2010, 07:47 AM
Proprietoristicly Refined
John_AZ's Avatar
Thanks for the chart +1
John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 11-16-2010, 07:58 AM
Custom User Title
mikepellegrini's Avatar
Originally Posted by S ECU Repair View Post
The Trigger to the Coil and Injectors are driven by the same signal that comes from the reference sensors ECU Doctors Team .
Which sensor powers which? I thought the reference sensor controls the spark and the speed sensor controls the injectors?
I vaguely recall something about the engine having to reach xx RPM for the injectors to fire? That the speed sensor?
83 944 NA - Black on black
86 951 - Red - SOLD 7/21
16 Ford Expedition
He who hesitates is lost.
Old 11-16-2010, 06:29 PM
Ok, This is where i am. I have #1,2, & 3 injector now firing. The car runs on three cylinders. I have power With a test light to the # 4 injector but I do not hear it clicking as I clearly hear the other three when I listen with a stephoscope. The chart above says #4,5 & 6 fire from pin # 15 on the DME computer. I can't seem to find the # 5 & 6 injectors (just kidding). My next question is does #4 really fire on it's own from the # 14 connector. If not I would expect the injector is defective. If so the computer or wire could be the issue.
Old 11-23-2010, 04:02 PM
John_AZ's Avatar
Injectors fire in pairs. See post #4
Injector Spray
GL
John
Old 11-23-2010, 04:10 PM
Inside the DME Pins 14 and 15 are joined to a single component ,so i believe you have a defective injector or somehow a damaged harness .
www.ECUdoctors.com
1-800-328-1425
Old 11-24-2010, 06:38 AM
