-   -   Help... can't open door from either side (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/575608-help-cant-open-door-either-side.html)
1968-912-coupe 11-16-2010 06:27 PM
I replaced the passenger side exterior door handle linkage rod on my '87 944.
I replaced the linkage rod, put the door handle back on the door and closed the door. When I went to open the door the door handle lever was jammed.
I realized I forgot to mate the shaft on the lever mechanism to the indentation on the linkage rod.
So I went to open the door from the inside and was bewildered to find that it wouldn't open from the inside either.
I had removed the door panel before doing this repair (for a separate reason) so I tried to force the linkage rod down from the inside of the door but it didn't work. I checked the power door locks and they're work fine.
Can anybody tell me how to get the door open???
mikepellegrini 11-16-2010 09:56 PM
It's odd the inside quit working - can't quite image why. It shouldn't a been affected by why you did.
Does the door lock actually operate? Or did that linkage fall off in the locked position?
Normally, a Slim Jim would work pretty well. You could probably get one of those from a locksmith or maybe Harbor Frieght.
