I have the opportunity to swap out my '84 AFM and ECU with a later AFM and ECU. I understand that the '85/2 - '89 AFM,s were identical. I will have an '86 AFM and a '88 ECU . Will that work , any thoughts?
Thanks |
Providing the ECU is for a 2.5L engine everything should work fine.
1984 - 944 Black / Wilwood/Brembo brakes / fresh M-474 suspension / Welt 250 lb fronts / 28 mm solid T-bars / M030 bars w Racer's Edge hardware/MSDS headers |
dkbautosports.com
i did it to one of my 944s (the 83) so i could install a chip . i found no big plus from doing it . i tryed 3 brands of deferent chips . if the part can be had for free or real cheap i would also do it to the 84 944 i have . some state they get bigger gains than i got . my guess would be about 3 to 5 hp at best is what i got .
upgrade
I'm wondering that at the very least it would improve idling and overall a better running engine.
Garage Helper
FRWilks is pretty good stuff and his customer service is great...always has been.
www.the944.com ©1999 FR Wilk <------------ there also besides frwilk.com
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now). ![]() UAV-M1 (Urban Assault Vehicle - Model 1) Bless the lowered, and pass the nitromethane. Pedal to the metal till you see the gates of hell then brake NLA - No longer available is a four letter word Last edited by Cocacolakidd; 11-19-2010 at 06:50 PM.. |
