Unhappy Engine Problem???
Ok today driving back from Europroducts half of a mile from my house the car starts to drive hard like it's dying and when I came to the light to turn the engine cuts off and quits running it turns over but will not fire. So I pushed the car over 4 lanes into a transmission shop. I pop the hood and can't find anything wrong so I run home call a friend so we can push the **** over my house. Well it looks like the belt tension went or something. Any ideas what this can be I'm staying home from school tomorrow to work on it. Any help any ideas on what it can be please share with me.
Seb
Old 01-22-2002, 04:57 PM
I hope you're not talking about timing belt tension. You could have lost an idler, jumped time & messed up some valves.
drew1
Old 01-22-2002, 06:26 PM
Don't know tomorrow I am going to take the belt housing off and going to take a look at the belts. Any ideas on what I should look for I know the mark on the cam sprocket and the bet to line up but anything else??
Old 01-22-2002, 06:32 PM
Well, don't know what kind of car we are talking about. I've never done any belts on a 928, but I asume the crankshaft TDC can be looked at though a hole in the bell housing. It should be a line, mark, "0" or something to line up with a pointer, I guess. This is on the rest of FE watercooled.
drew1
Old 01-22-2002, 07:05 PM
It's an 951 1986. Sorry I didn't say that earlier.
Old 01-22-2002, 07:13 PM
Bob's944's Avatar
Send a message via AIM to Bob's944
Porsche Crest
Hey!!! Don't be bending his valves already... could be a few other things, DME relay for one. Fuel pump may have died or even a coil failure. Check for spark, if your gettting spark out of 2 plugs, then your belts are OK and your coil too. If not, bad coil or rotor broke. If you smell a strong gas odor, then I would doubt you have a fuel pump failure. Relays are cheap. I'll cross my fingers for ya.
Old 01-22-2002, 07:49 PM
It's my timing belt tension that went I blew the bearing out.
Old 01-23-2002, 08:17 AM
All I have to do when I put the new tension on is line up the TDC marks on the cam sprocket??? Then I put the belt on and tension it right? This is an 86 951.
Old 01-23-2002, 09:36 AM
The lower balance shaft sprocket suppose to line up with I don't see jack ****
Old 01-23-2002, 01:30 PM
88_944's Avatar
I got bad news, If the timing belt tension bearing went out then you have jump timing and some of your valves went too. You can't be 2-3 teeth out of timimg. Check to see if the belt is very loose. If not then mabe your safe and the valves are safe. But if not I have to ask you this, when the car stop runing did you tried to start it up? I hope not because you're spinging the crank and hitting the valves bad.
If you bent the valves, you have to take off the head and change all the bad valves. I had this happen to me when I had a 83 944 and I did the job my self. Save me over $3,000! The turbo has more things to take off but do it and save and be proud you can be a porsche mechanic. I work on 944 heads, main and con-rods bearings, cluch, oil cooler, water pump, oil pump Damn only the trans I have to learn.
My Black 944
My Gaming Forums. Xbox360gen.com
Old 01-23-2002, 02:58 PM
Usually, Turbos don't bend the valves.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 01-23-2002, 03:49 PM
I'm going to put everything back together and see what happens. If the valves are bent then I'm screwed. Hopefully I can manage and do the belt right.
Old 01-23-2002, 05:05 PM
Let's hope valves are alright then.
Put your new tensioner on. No need for new belt yet unless teeth are sheared on old one.
As far as lining every thing back up. Take the plugs out so the motor will turn easier. Get a socket, 22mm I think, & short extension with ratchet or pull handle. Put the socket on crank pulley bolt & turn clockwise, feeling for resistance. When you get close to lining the mark on pulley up to the pointer on timing cover back, start checking the hole in the bell housing for TDC mark. Go a little bit at a time so you won't pass it. When the TDC on flywheel is lined up with pointer, you're at TDC. Now loosen idler enough to jump teeth on cam pulley to line up cam pulley to its mark. I'm pretty sure you're going to be off some or you would crank up.
With every thing in line, cross your fingers & fire her up. If she starts your valves & all are OK. Now while you've got all that stuff off, get it back to TDC & put on new belts, check balance idlers.
I'll do a search of a post I made with balance shaft pulley alignment & edit to give you the date, etc. It will keep me from typing so much.
drew1
edit: thread: balance shaft belts
posted by: tri
date: 08-15-2000
Old 01-23-2002, 05:15 PM
Seb,
That car alright?
drew1
Old 01-28-2002, 07:53 PM
Thanks for asking it's not ok but I'm going to do the valves on it and line everything up at TDC once I install everything. But I don't have time to work on it school and I need to get rid of the 944 that's sitting in my yard well let me say that again I need to get rid of the 1/3 944 sitting in my yard anyone need parts lmao.
Old 01-28-2002, 08:03 PM
