Hey guys,
Just reached 150k and thought it was about time to do the cambelt as it hasn't been done since 120k. It looks really awkward to get to. What is the best way to get at it? Looks like the radiator has to come off? kind regards Will |
Hi Will, Check out Clark's Garage.com for how to change out the Cam and Balance Belts at the link below. Should give you all the information on how to do it.
Timing Belt and Balance Shaft Belt Installation Cheers, Larry
Retired USAF and Civil Service, 1985.5 NA Graphite Metallic, A never ending work in progress, 1992 968 Horizon Blue Cab "New Toy"
I don't think you have to pull the radiator but it helps free up a bit of space so it's easier to work. The hoses get in the way also. The radiator comes out EZ.
Check out Arnnworx for good info and tools.
Red 83 944 |
Rocket Surgeon
You don't have to pull the radiator but it's nice when the fans are out of the way. You don't need to pull them, either, though.
What is your level of technical expertise? Things look a lot less tricky when you're used to wrenching, but it IS daunting at first. What year is the car? Turbo or not? What got changed at 120k? Rollers/water pump/hoses/front seals?
'89 951S, Velvet Red Plymouth Superbird, Corporation Blue Plymouth Superbird, Blue Fire Metallic |
Pulling the fans is super-easy. Just 6 screws and two connections. Plus you can use this as an opportunity to clean those connections!
Hey thanks so much all,
The clarks guide is great cheers
All Spooled Up
It really only only needs to be changed every 40-50K miles, depending on how much oil is making it's way through the front seals. Unless you've got yourself a gusher, you are jumping in to it a bit early. But it certainly won't hurt anything. The cost factor is negligeible. But the hassle factor is what would cause me to hold out for another 10k, or so.
JUST A REMINDER: DO NOT TURN THE CAMSHAFT while the crankshaft it at either TDC or BDC. If it needs to be turned when the belt is off, ONLY do it after making sure the crank is 45-90 degrees away from TDC or BDC.
>gray 89 951S - K27/8, MAF, 3" intake, 3" exhaust w/separate waste pipe, 55# inj, late cam; >red 87 924S - chip, K&N, punched-out cat&muffler >black 80 924 - (sold) >maroon 77 924 - auto (sold) Last edited by wild man; 11-30-2010 at 05:29 AM.. |
When I changed the belts on mine I didn't take the fans or radiator off, but it really helps to jack the car up enough to sit in front of the motor. also make sure if you need the rollers or not, the cambelt kit is cheaper than a broken engine.
Mark S. Certified Porsche Newb Alea Iacta Est. 1987 924S 67k miles, all stock besides weltmiester Throttle Cam 87 944 Turbo shes got a few goodies. New DD |
DO NOT LISTEN TO WILD MAN! Repeat after me, "I WILL change my belts every 3yrs OR 30k miles, whichever comes first!"
No you do not need to remove the radiator, mine was due for a proper cleaning though and it made the job MUCHO easier. When was the water pump last done? Now is the time to do it as well... |
All Spooled Up
Hey, I'm not saying that it's going to hurt anything. And if there's decent amount of oil getting onto it, it might not even be such a bad idea. And it's always a good idea to check your WP and rollers (and seals, also), while your in there.
>gray 89 951S - K27/8, MAF, 3" intake, 3" exhaust w/separate waste pipe, 55# inj, late cam; >red 87 924S - chip, K&N, punched-out cat&muffler >black 80 924 - (sold) >maroon 77 924 - auto (sold) |
