overkill's Avatar
Send a message via AIM to overkill
Geeezus! My cooling fan stilling running while engine is off for 2.5 hours!!!
On top of the whistling coming from my intake manifold area now my cooling fan is running for like 2.5 hours after the car if off! I had to go to work so I dont know how long it would ran for. That is not normal! Any ideas on whats up? Damn I need this car to last until I pay off all my dept before I start spending butt loads of cash on it! About the whistling...the higher the RPM, the more high pitched it gets. I hear it coming from the intake manifold area. I did put injector cleaner in the gas tank about a day ago, if that matters.
{1987}944S - (SOLD).
Old 01-24-2002, 08:20 PM
Send a message via AIM to jeh1995
My bet would be the thermoswitch that controls the fan. I had to replace mine. It would run forever but only intermittently. No problem once I replaced the switch. This is the switch on the drivers side of the radiator. I have a '86 944 in case yours in different.
Old 01-24-2002, 08:35 PM
AFJuvat's Avatar
Your fan problem is most likely one of two things:
1. Your thermoswitch is shot (which is usually the most common) (About $20 or so to replace)
2. Your fan relay is shot (on the later models it is that big one closest to the windshield) (About $120 or so to replace)
As far as the whistling in the vicinity of your intake manifold, there are several possibilities: Basing this on your statement that it is whistling (which whould imply an air leak somewhere) as opposed to a whining (which would imply a bad bearing - probably in your belt rollers)
From easiest/least expensive to more difficult/more expensive:
1. Make sure all of your hose clamps are tight.
2. Check your intake boot between your airbox and the throttle body/intake manifold for cracks/tears etc. (About $50 - 75 to replace)
3. Using a flashlight, look at the vacuum hoses under your intake manifold for cracks. Also, inspect the vacuum hoses you can see for cracks. Pay particular attention to those small hard plastic hoses. Replace as necessary - vacuum hose you can get in any auto parts store - the small hard plastic ones you have to get from a dealer.
4. If you can't find the cause from the above - it is possible you have a vacuum leak in one of the lines under the intake manifold. Remove the manifold and inspect your lines. Then clean the intake, throttle body, and airbox/AFS completely. Then replace your intake gaskets and fuel injector O-rings and put everything back together.
5. Last/worst case scenario - cracked intake manifold (This is most unlikely)
Hope this gives ya a point in the right direction
AFJuvat
Old 01-24-2002, 10:18 PM
overkill's Avatar
Thanks ill take a look!
Old 01-24-2002, 11:06 PM
ribs's Avatar
Re: Geeezus! My cooling fan stilling running while engine is off for 2.5 hours!!!
Well...I had a lot of whistling and other air noise in my celica all-trac. It sounded like it had a blow off valve, as every time you would shift gears, it would go "whoosh", and there was whistling and rummiging noise whenever the car was on boost. I had to take my intercooler off to replace my plugs and wires, so I cleaned it out really really good with some carb cleaner and some other degreaser stuff, and sprayed the rest of the bottle of carb cleaner and degreaser stuff down the throttle body (with it open) and in the intercooler tubing. I don't know what the engine sucked out of the throttle body/intake runners, but when I ran a hose (you know...water) through my intercooler to try to get all of the gunk out, there was massive amounts of chunky oil boogers with foreign organic matter attached to them...it must have been 6 or 7 ounces of this crap that came out (the car's previous turbocharger was leaking oil really bad from the seals...the rebuilt turbo runs like a champ...that is my guess where the oil came from).
Anyways, once I got the car all put back together, there was no BOV noise (the 3S-GTE motor in the celica doesn't have a BOV or bypass valve...the 3S-GTE in the MR2 turbo does have a bypass valve...strange, huh?), no sucking, whooshing, or turbulence noise. It must have been the oily funk in the intercooler and/or throttle body/intake runners that were making all the stink. So, the moral of this story is...clean out your intake manifold with some carb cleaner, and see if that helps. It helped a ton for me. I know...its a different car, but the same principals apply.
Rich
'86 951, gone for 10+ years
Old 01-25-2002, 12:05 AM
overkill's Avatar
Will do, I'm new to this stuff so i'm kinda nevrous but egar at the same time.
Old 01-25-2002, 01:12 AM
Hmmmmmmm.... Sounds familiar
http://www.pelicanparts.com/cgi-bin/vb/showthread.php?threadid=13854
Old 01-25-2002, 12:14 PM
