Guages???!???
How do you take out the instrument cluster/guages??? I have a 1987 924S.
Very carefully?
1984 - 944 Black / Wilwood/Brembo brakes / fresh M-474 suspension / Welt 250 lb fronts / 28 mm solid T-bars / M030 bars w Racer's Edge hardware/MSDS headers |
Very funny! I need details! What do I need to remove or unclip or whatevers holdin that thing back!
Good luck, George Beuselinck |
If you have a small vice-grip it makes removing the speedo cable very easy if it still has the factory locktite on it. Also, don't even try tto remove it with the flasher and wiper stalks in place. spend half a min and remove them- its much easier, just remember to hook the high beam lever back on to the switch.
All Spooled Up
Any similar instructions for removing LATE gauges (instrument panel and ABS stalk).
>gray 89 951S - K27/8, MAF, 3" intake, 3" exhaust w/separate waste pipe, 55# inj, late cam; >red 87 924S - chip, K&N, punched-out cat&muffler >black 80 924 - (sold) >maroon 77 924 - auto (sold) |
