jamesjedi's Avatar
OPRV and OPSU
I have an 86 NA. My car is running very rough with high oil pressure. How can I check the OPRV and the OPSU? I have searched and not found an answer.
I do not think that it is the OPSU that is causing the problem because the oil pressure was strong enough to push my dipstick out. Also, there is no reading with the key in and the engine not running. I would like to rule out OPRV, how do I check it?
Old 10-22-2010, 11:57 AM
Proprietoristicly Refined
John_AZ's Avatar
You have a '86 944 (please update your signature line)
You should have the late OPRV-----just to be sure, compare it the the pictures in the tech article below.
There is no way to "test" an OPRV. If you feel it is giving the wrong reading, you should replace the "O" rings. These usually decay and cause problems. Clean the OPRV parts.
Get a new aluminum crush washer or the OPRV will drip when installed.
To rebuild-----see post #4
Using SeaFoam Product
To see which OPRV you have:
http://www.944online.com/pdf/oilcoolertech.pdf
Pelican has the "O" rings.
GL
John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 10-22-2010, 12:41 PM
All Spooled Up
I don't think it's possible for oil pressure to be high enough to push out the dipstick. Most likely either a blocked air/oil separator, or excessive blow-by.
Is your pressure gauge pegging out at over 5bar when warm?
>gray 89 951S - K27/8, MAF, 3" intake, 3" exhaust w/separate waste pipe, 55# inj, late cam; >red 87 924S - chip, K&N, punched-out cat&muffler >black 80 924 - (sold) >maroon 77 924 - auto (sold)
Old 10-24-2010, 09:18 AM
jamesjedi's Avatar
At first I thought it might be blow-by. The oil pressure is now coming down after it is warm. To about 3.8 at idle. It is pegged at 5+ until the engine has completely warmed up. It is still running rough at idle. At higher RPM's the engie sounds good.
How can the air/oil separator be checked? I also want to take out the OPRV to inspect and reinstall. Do they simply "bolt back in" , or do they have to be aligned?
Old 10-24-2010, 10:54 AM
Toofah King Bad
Rasta Monsta's Avatar
If you don't disturb the oil cooler housing, you should be able to R&R the OPRV without realignment.
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 10-24-2010, 11:37 AM
John_AZ's Avatar
Rasta is correct.
Clarks says to replace the crush washer and the "O" rings if you remove.
Found at bottom of page.
Oil Pressure Relief Valve General Information
GL
John
Old 10-24-2010, 12:01 PM
All Spooled Up
It's been quite a few years since I've been into one, but after you unscrew the retainer plug, you should find the spring, and the the moving part of the valve behind it. If my recollection is correct, there is an O ring on it, which might be getting stuck. You may want to try to clear out blockage in the AOS by pushing compressed air through it in reverse direction, with the filler cap removed.
What weight of oil are you using up there?
Old 10-24-2010, 12:11 PM
jamesjedi's Avatar
Do you mean blowing air into the oil fill hose?
Old 10-24-2010, 01:34 PM
All Spooled Up
No. I mean blowing air into the hose that feeds from the unit into the air intake boot, near the throttle body. But make sure that you have the oil filler cap off, and probably also the dipstick out, to prevent pressure buildup.
Old 10-24-2010, 02:18 PM
jamesjedi's Avatar
I will try it. Everyone, thanks for help. I will post the results.
Old 10-24-2010, 02:57 PM
jamesjedi's Avatar
Update
Well....I got a chance to look at the car today. Before I did any of the recommended steps to reduce oil pressure, I looked at two spark plugs. One was wet, the other was a little oily. Also, had a look at the oil refill cap, it has a a small amount of coffee cream. I now know that coolant is getting into the oil.
If I do a leak-down test, will it give me an accurate read if the head gasket is blown? Or, is the head gasket issue due to the high oil pressure? Either way I will have to deal with the head gasket. Not sure what to do next.
I want to determine if there are other engine problems.
Old 10-25-2010, 01:06 PM
Send a message via Skype™ to massive
Check out my blog 944 Foot To The Floor: How to remove and replace OPRV (Oil Pressure Release Valve) on a Porsche 944 you might find some useful info about the OPRV there.
Old 10-25-2010, 04:41 PM
John_AZ's Avatar
Dave, aka massive.
Great pictures and write up. I will use your information and link to help others.
I do have a problem with your final comment and information from the Porsche mechanic. See pic.
Do not use the OPRV as an alignment tool if the housing comes off.
Your Porsche mechanic has years of knowledge and the "feel" needed to prevent an OPRV from binding. Members doing the OPRV housing for the first time, do not have this "feel" for a binding OPRV. The alignment tools are required for this procedure for a novice mechanic.
I was unable to comment on your web page.
But, again excellent pictures and writeup.
John
Old 10-25-2010, 05:09 PM
Cheers for the praise, yes totally agree you do need a bit of a feel for these things sometimes. I would say though that removing the oil cooler is beyond the scope of most novice and indeed even some amateur mechanics. But if you have reasonable common sense you should be able to perform the realignment using the OPRV, just making sure the oil cooler doesn't slip whilst you're tightening up the mounting bolts.
Originally Posted by John_AZ View Post
Dave, aka massive.
John
1984 944, 2.5L, manual transmission, UK right hand drive.
http://944foot2thefloor.blogspot.com/
Old 10-26-2010, 01:48 AM
jamesjedi's Avatar
I have found that in my endless searches for information on this site, all to often there is no conclusion/solution to the problem. I appreciate the help and I will follow this thread through.
I plan on removing the OPRV for an inspection. Blow the AOS, then I will do a leak down test with the engine cold, as I do not want to run it any more. I just have to wait for the Longacre leak-down tester to arrive in the mail.
I hope to find the pistons and cylinders in good shape when the leak-down test is done. Thanks for any help that has been provided.
John, the pictures and write up are excellent.
James
Old 10-26-2010, 06:05 AM
You can post a comment at the bottom of each write up
John
Old 10-28-2010, 02:09 AM
jamesjedi's Avatar
Could my problems be caused by a leaking oil cooler?
I will be doing the leak down test in a few hours.
Old 11-05-2010, 06:07 AM
jamesjedi's Avatar
I have replaced the oil cooler seals. As I had the old style, I simply inserted it and tightened. I have also replaced the cylinder head. Engine is now running.
I went on a test drive and the dipstick has pushed itself out again. When i removed it while engine was running, I could see there is puffing coming from the tube. Any thoughts?
James
Old 11-18-2010, 09:13 AM
burn piston and or broken ring is possible. I have only seen combustion pressure blowing dipsticks
Old 11-18-2010, 09:47 AM
Back from Beyond
Time for a compression test, I think.
'88 944 Auto - project, kinda
'87 944 Auto - died saving my wife
'84 944 5SP - crushed under shop roof during snow storm
All others GONE!
Old 11-18-2010, 10:24 AM
