944.5 Front side marker light
Hello to all
Does anyone know if there is a bulb in the front side marker that can be replaced or does the whole thing need to be replaced?
Old 01-27-2011, 01:54 PM
pjs77's Avatar
**Update - MY BAD** I stand corrected...see response below
I don't think you can just swap out the bulbs. Check out this thread from a quick google search
Replacement of front side marker light bulb - RennTech.org Forums
And here is the Pelican diagrams...not cheap. You might want to source a used one from a fellow Pelican member. Good luck and welcome!
Pelican Parts - Product Information: 944-631-411-00-OEM
Paul - Norwell, MA
1985.5 944 Guards Red N/A
Koni Sports, S2 sway bars
Old 01-27-2011, 02:05 PM
The bulb can be changed. It easiest to remove the lens first to get access.
The bulb socket has a twist lock fitting attaching it to the lens.
So just give the socket a gentle twist and it should separate form the lens and expose the bulb.
Old 01-27-2011, 02:21 PM
