| Registered Join Date: Dec 2001 Location: ventura,ca
				fuel lines
			i got one mech. saying to replace fuel line with factory parts, and another mech. saying cut out the old and replace with hose and hose clamps....... one says its a high pressure system  and hose clamps are not real good, the other says different....  any input, cruzer, polishing the wheels for the sunday cruz | ||
|  02-02-2002, 02:03 PM |
| Registered Join Date: Feb 2001 Location: Buzzards Bay, Ma, USA
			It is generally not a good idea to replace factory lines with hose and clamps. The fuel system  does operate under moderately high pressure.   If you do go this route  make sure the hose is rated for the pressure (most is) and double clamp everything.  Also, retorque after a few days.  I wonder if there is some shop out there somwhere that could make up lines to your specs. It might be cheaper than going back to Porsche. Hope this helps, Jon Aborn | ||
|  02-02-2002, 03:16 PM |
| Registered Join Date: Feb 2001 Location: Viera FL
			Especially now that Porsche changed the part to three different parts. (it went from one big hose to 2 hoses and a coupler) If you have the newer hose, you can just replace the one you need. If you have the older one, you have to tear the whole thing out - which entails moving, disconnecting etc, a good chunk of your rear suspension AFJuvat | ||
|  02-02-2002, 04:50 PM |
| Registered Join Date: Dec 2001 Location: Cordova, TN
			dont use fuel spray near the ignition system will cause a fire if you want another alternative use steal braided line and the right fittings
				__________________ Roger Hall 81 924 N/A Some people are like Slinkies. Not really good for anything, but you still can't help but smile when you see one tumble down the stairs. | ||
|  02-02-2002, 04:51 PM |
