-   -   Annoying Problem.... (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/58830-annoying-problem.html)
Amurley 02-02-2002 10:42 PM
I have an annoying problem with my 1985 1/2 Porsche 944. This problem comes and goes (almost with weather changes). Last year I stored my car and when i took it out there was a problem that once you hit 1800 - 1900 rpm I lose all power but the car does not cut out... it just drops to idle speed and once it hits 1800 - 1900 rpm it drops again.
At first I thought it might simply be bad gas... no such luck:( . The car has gone through a few tanks of fuel since then.
Next I decided to do the cheapest thing (seeing as i'm a student) and i replaced the fuel filter... no such luck... the problem returned.
The problem usually goes away for weeks at a time with regular city driving but returns with any aggressive driving or spontaneously just for fun :rolleyes: .
As today is groundhog day I would like to get my car ready for the road again (we have too much snow and road salt for me to drive in the winter). If anyone has any idea what is happening please help.
Some unexplored or slightly explored areas are vacuum leaks and fuel pump.
Also, I was told that the car had a computer (to my surprise) and would like to know the "codes".... Thanks, Amurley.
Amurley 02-03-2002 09:47 AM
When I said power by the way I meant push power... not electrical... just thought I'd add that.... thanks... any help is greatly appreciated...
Magnus_944 02-03-2002 10:00 AM
I might be the Throttle Position Switch. Check it according to the Haynes manual.
//Magnus
Amurley 02-03-2002 10:02 AM
ok... thanks... i'll check that out...:D
3sonfather 02-03-2002 12:25 PM
This can be a real bear to solve. I chased a rev limiting condition for months - couldn't get above 4500 rpm. I replaced what looked like a bad speed sensor still to no avail. Then I began to tinker with the air flow meter and found I could change the point that it would cut out by adjusting the wiper position. This also made the car run rich or lean depending on the setting. Ultimately I swapped out the AFM and that cured my troubles.
Amurley 02-03-2002 01:56 PM
is it a pricey procedure to replace the AFM (air flow meter)?.... I'm making a list of possible problems and i'm going to sort it from cheapest to most expensive ;) i've got a little time because the damned groundhog saw his shadow :p and that means six weeks more winter (at least).
Crippler 02-03-2002 02:04 PM
Sorry for this being totally unrelated, but I was just wondering what part of Canada you live in.
Amurley 02-03-2002 02:07 PM
Eastern Canada... New Brunswick... which leads to another problem.... the nearest authorized dealer or service centre is in Ontario...http://www.pelicanparts.com/support/smileys/splat.gif
Crippler 02-03-2002 02:09 PM
hey, I live in Fredericton. Where do you live in NB?
Amurley 02-03-2002 02:12 PM
Fredericton....
Crippler 02-03-2002 02:14 PM
1 Attachment(s)
Well that is interesting, what's your name, what does your car look like?
My name is Kent Staples and here is a pic of my 1984 944.
Amurley 02-03-2002 02:16 PM
Andrew Murley... have i seen your car on campus?...
Crippler 02-03-2002 02:18 PM
yup, its the only black 944 on the unb campus that I know of. I just wish all of this snow would go away so I could get it back out. Is yours red?
Amurley 02-03-2002 02:19 PM
my car is red and in need of some cosmetic work (besides the problem that made me join this forum).
Crippler 02-03-2002 02:27 PM
There are not many 944's here in Fredericton, but here are the one's I know of.
White 944 n/a (late dash)
1989 944 black (is never driven has engine troubles)
944 turbo of some year, red and lives in New Maryland, I have never seen it,but have heard of it.
My 1984 944
and your 944
Anyways it is nice too talk to some one in the city with a 944. Oh and sorry I can't be of any help with your problem.
Amurley 02-03-2002 02:38 PM
There is also a gold coloured one... i saw it last year.. had any service done in town?
Crippler 02-03-2002 08:17 PM
I had my belts (timming, balance) done at york auto service, uptown off bishop drive. They overcharged me on the belts, but they did know what they were doing and did a good job. So it was worth it because they are not something to fool around with. I do all the rest of my service myself and order most of my parts from the Porsche dealership in Calgary. I have also ordered a few from Performance Products, but it is usually alot cheaper to order from the dealership.
Cebu 02-04-2002 05:32 AM
Your problem associated with weather, and hard acceleration..I too, would suspect the AFM as a priimary cause of RPM instability. Air density/temp. weather related and underhood temperature related to driving time and hard acceleration.
Amurley 02-04-2002 10:22 AM
ok... thanks... i'll definately check that out asap.
Amurley 02-04-2002 01:59 PM
Cool... any idea what a throttle switch will run me?.... Thanks alot... mechanics around here don't know **** about these cars... except one guy...
