SLED GUITARIST
Dan Himan's Avatar
Engine removal
Can I remove my 944S engine with out pulling the dme harness thru the fire wall? I see I can disconnect the connections in the back area of the block when I am lowering the engine. There is the idle stabilizer valve connection under the intake that might pose a problem.
1988 944S Guards Red---Hers FRWilks Chip, MSD Blaster 2
1987 944S Blue Diamond Mine Crankscapper, MSD Blaster 2 Coil, Weltmeister Race chip, Sports pack. Hit by a sleeping driver at 2pm, soon to be the Black and Tan
1985 944na Gray---His Eibach Gound Control Struts/Koni Rear, Throttle Response cam. SOLD
Old 02-19-2011, 07:33 PM
so just disconnect all the connections on engine side of the harness. not that many. two for raidator and ect sender, two for oil pressure, 1 for tps, 1 for afm...think there's another two for emissions stuff, speed/ref sensors....i think that's about it. might be another couple that i missed
Old 02-19-2011, 10:05 PM
It's much easier to just pull the harness.
Old 02-20-2011, 07:27 AM
If you don't want to remove the intake and possibly the timing belt cover to get to all the cables and cable ties you should pull the harness. I left it in the car, but in hindsight it would have been easier to pull it.
1990 944 T: 100 000 km/63K miles,
1997 986 2.5L: 95 000 km/60K miles,
Living in the trackless land of plenty!
Old 02-20-2011, 07:43 AM
