thermostat jiggles
new(rebuilt?) water pump on engine rebuild. so i put the thermostat in and heard the clip "click" in the groove, but the thermostat has about an 1/8 inch "play". when i ordered the thermostat i was told that i would need a spacer only if it is '89 or newer. mine is an '88, 944 turbo. perhaps i was sold a newer water pump. the pump install fit fine...so do i in fact need a spacer, please advise.
thanks,
rick
1988 944 turbo
Old 03-12-2011, 08:43 PM
Hi Rick, I installed a new turbo water pump on my NA along with a temperature matched thermostat and radiator thermo switch. I had an inner seal, thermostat, an outer seal and then the "C" Clip. There was NO play at all. Where you are located it gets hot hot same as middle Ga.. My set is in the late 70's temperature wise as you want the fans to come on when the thermostat opens allowing the hot liquid to flow.
Cheers,
Larry
Retired USAF and Civil Service,
1985.5 NA Graphite Metallic, A never ending work in progress,
1992 968 Horizon Blue Cab "New Toy"
Old 03-12-2011, 09:42 PM
Proprietoristicly Refined
John_AZ's Avatar
There is a shim washer but thermostats should come with 2 different thickness thermostat outer seals. Some WPs have bigger grooves
944 106 929 08 is 4.5mm thick
944 106 929 05 is 2.5mm thick
The blue item is the shim washer.
GL
John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 03-13-2011, 06:11 AM
ah ha! mine is clearly the 4.5 variety...thank you john.
super stoked,
rick
1988 944 turbo
Old 03-13-2011, 09:10 AM
