please help
Ok, my 87 944na with a few mods is having the weirdest problem. This just started today. when i floor it, it goes through the gears to about 5krpms, then the power suddenly falls off and it stays at 5krpms, its really annoying. It picks up through all rpms, dies a little at 4.6k rpms, then just stops accelerating at 5kprms, then when I shift it does the same thing in every gear. Could this be due to a problem with my performance chip rev limiter? I've had the chip for about 6 months, no probs yet. Any ideas please. This started for no apparent reason, just this morning, and it won't go away. Thanks for any help.
Brendan.
1987 944na, black on black, sex change(auto to MANual), msds headers, europroducts.net chip, msd 6a ignition system, msd blaster 2 coil, nology hot wires, aluminum interior from www.presigepartsco.uk, bad ass stereo system, badass alarm system, momo combat shift knob
Old 02-11-2002, 06:15 PM
sounds like you have a fuel mixture problem,,,, check your vac. lines
Old 02-11-2002, 06:44 PM
I upped the dme mixture 3 % a couple weeks ago, could that have done it? How do i check my vac lines? Should i return the dme to normal and see if it goes away? Thanks.
Old 02-11-2002, 07:00 PM
Roger Hall's Avatar
rev limiters are usually not that smooth when you exceed the limit rpms will drop if you continue to press the throtle the engine will shudder as it tries to exceed the rev limiter check the vacum line by srpaying brake cleaner on them if the engine sucks in the brake cleaner the rpms will rise im chasing a power loss problem too its a pia
Roger Hall
81 924 N/A
Some people are like Slinkies. Not really good for anything, but you
still can't help but smile when you see one tumble down the stairs.
