930 (7s and 9s) on early 951?
Hi,
New over here and did a search but it only yielded half and answer...
Seems like the stock 9" 930 fuchs will fit on the rear of the 86 944 turbo. Anyone know if the stock 7" 930 fuchs will fit on the front? If not, what is it that needs to be done...if it's even possible? I'd love to just bolt my set up.
Thanks,
John
Old 03-15-2011, 07:31 AM
931GT's Avatar
You'll need the 951 8s on the front. 911 offset 7 and 8s don't fit around the brakes.
Currently Without Porsche
1981 931GT (SOLD)
1985 911 Carrera Targa (SOLD)
Old 03-15-2011, 09:35 AM
racer's Avatar
7's can fit with a small spacer (3-5mm). the issue is the 911 part numbered 7"s have a slightly different mating surface which will cause the wheel to rub the brake caliper. 951 part numbers 7s, or 8s, will bolt up with no additional needs on the front of an '86 951.
Past:
2000 Boxster 2.7, 1987 944, 1987 924S
1978 911SC, 1976 914 2.0, 1970 914 w/2056
Old 03-16-2011, 08:55 AM
