Timing belt tension check tool
I have a 1987 Porsche 944 non turbo. I'm doing the timing belt, water pump, and pulleys. I found on ebay a tension checking tool from Mechanicstopia model number H-EN0136. I was wondering if any of you have tried this tool and how it stacks up against the infamous P9201.
Old 03-14-2011, 07:01 PM
meister member
speedracing944's Avatar
Sorry I can't comment of the other tool as I have the P9201 and enjoy using it. I am not afraid to really did into the engine. Having the tool has probably saved $4000 in paid vehicle maintenance thus far. I think it is worth every penny.
Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 03-14-2011, 07:08 PM
i don't see how u can even use that tool...it's shown on an accessory belt in the picture on ebay auction. something that sized....i don't even know where you'd put it on the belt. possibly at the idler roller...assuming u remove the roller.
Old 03-14-2011, 07:15 PM
Toofah King Bad
Rasta Monsta's Avatar
I'd like to test one against the 9201. . .looks interesting.
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 03-14-2011, 10:04 PM
I brought this up on another board when I first saw this tool. It was on E-Bay. Someone said they had tried it and it was too large and had some kind of calibration numbers not easily converted to Porsche requirements (whatever that meant). I use a Krikit, the thumb and forefinger twist test and the water pump pulley twist test as a check against each other and nothing has broken yet.
Old 03-15-2011, 06:54 AM
Parrothead member
VINMAN's Avatar
Twist test.
That is all. Carry on.....
Vinny
Old 03-15-2011, 07:12 AM
Proprietoristicly Refined
John_AZ's Avatar
Harbor Freight used to sell a version of the tool.
I cannot find the tool for sale on HF anymore.
How can it fit to test the cam belt?
Maybe it can't.
John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 03-15-2011, 07:16 AM
FLYGEEZER's Avatar
Gotta agree with VINMAM on this issue. Been using the "twist" method for 25+ years on mine & other 944/924S .Belt repacement & retension is essential but the very expensive P9201 tool is not. IMO
Edgar
1984 Porsche 944 bone stock
1995 Mercedes E320 wagon
1970 Honda CB350 mint!!!
Old 03-15-2011, 07:37 AM
This may help you out. In 87 944 went an auto tensioner for the timing belt. The counter balance belt you need to adjust.
Old 03-15-2011, 08:16 AM
Toofah King Bad
Still needs to be checked post install with P9201.
Old 03-15-2011, 08:32 AM
John_AZ's Avatar
Yes,
The "auto tensioner", AKA the spring belt tensioner, or more accurately, the "mechanical belt tensioner" (Porsche) has provided another "tool" to adjust the belt tension.
Sadly, the mechanical belt tensioner is not accurate.
The novice mechanic who trusts this will pay for their lack of knowledge.
There are so many things wrong with this method.
Such as...
Spring tension factory setting and current "memory" of the spring after years in fixed position.
OR
Initial belt tension on the passenger side of the belt will skew the "mechanical belt tension" adjustment to severe cam belt over tightening.
OR, (3,4,5,6...)
You cannot trust the spring mechanical auto tensioner.
John
Old 03-15-2011, 08:35 AM
Automotive Necromancer
SolReaver's Avatar
Send a message via Skype™ to SolReaver
advocating independence
If you know what you are doing, you can tighten the belt(s) without a tool. The so called auto tensioner, really isn't unless you properly calibrate it. IOW the auto tensioner is notoriously inaccurate. The auto tensioner gets you to within the ballpark and properly sets the tension at a point other than the tdc. Better to set the feel by ear and feel. Either a shade above or below where the auto tensioner sets it.
Save your money and get a good set of triple squares, some 27 thin wrenches, fw lock, and a pin sprocket wrench. The 9201.... neat bit of overly obsessive toolbox candy.
There may be nothing quite as expensive as a cheap Porsche: Ruby Red 84 928S : White 87 924s 2.5L NA (Blinky) M44/07-43H10676 spoiler delete - 046/2B - Belts 9/12, Clutch and OC seals 8/08 andd Red 94 Del Sol: Please put your Make, Model and Year in Sig. Try not to break more than you fix.
Old 03-15-2011, 08:40 AM
Aslet's Avatar
FYI: I tried to buy the P9201 from Pelican about a week ago and they couldn't get it from Porsche. So the original and best P9201 may no longer be an option.
Old 03-15-2011, 05:25 PM
Where are some places that offer p9201
Old 03-15-2011, 06:08 PM
meister member
When I went to buy my P9201 new I got a quote from Sunset Porsche.
SUNSET | Portland, Oregon Porsche & Audi Dealership, Parts & Service
I ended up purchasing a barely used unit from a fellow Pelican for 1/2 the cost of new.
Speedy
Old 03-15-2011, 07:01 PM
John_AZ's Avatar
$350 to $550 3 or 4 Xs a year on ebay.
John
Old 03-15-2011, 07:26 PM
twist it over 90 degrees, belt is too loose. cant twist it 45 degrees...to tight
1988 944 turbo
Old 03-15-2011, 07:43 PM
