James Chimney
Spaced Out
I got my wheel spacers installed today (1 1/2" thought it was very wide till I put the rims and tires on and it looks fine) and installed my new 16" Phone Dials on my 85.5 na, they look great and they look like they belonged on this car from day one. slight shimmy/wobble in the front any idea's how to remove this (I watch wheels be balanced so they are ok)?
James
Old 03-12-2011, 02:56 AM
Proprietoristicly Refined
John_AZ's Avatar
Shimmy can be caused by not having a front 1/16th inch toe in.
Other theories:
Put the wheel lock opposite the tire valve.
Balance the wheels "on the car"
Worn suspension parts.
Inherent to the 944........
Here is some discussion.
Vibration at 60-80? Getting frustrated... - Rennlist Discussion Forums
GL
John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 03-12-2011, 04:53 AM
Griffinroydonal's Avatar
Please show us.
Warning - I play with Porsche's
1970 -914 / 1982 -911
1984 -928 / 1987 -928
Old 03-12-2011, 07:52 AM
James Chimney
Other theories:
GL
John
every thing was fine with old 15" rims and tires only thing new is the 7 x 16 phone dials and G-Fource tires and 1 1/2" spacers
Old 03-12-2011, 12:01 PM
Perhaps one of the spacers is not setting on the hub correctly. Maybe the center cavity is not large enough and is slightly off?
Jaime O.
Thank god I crashed or i would never have owned a porsche
83 944 daily driver (clutch and tt time)
85 325e BMW T-boned R.I.P.
Old 03-13-2011, 10:01 AM
Pete R's Avatar
You may have a problem with one of the tires, even if they are new. broken belt ect. can you rotate them around to see if you can get the wobble to move to the rear? You could narrow it down between a wheel/tire issue and suspension one. They may have not balanced it correctly or a weight could have been knocked off too.
1979 928 85 Euro 2v motor,S4 Brakes and suspension, 1988 951 street legal track car(sold)
Neon SRT4 track car
Old 03-13-2011, 11:12 AM
porscha
matty89's Avatar
or the balancement machine is just not calibrated guys ! i put weights in and out and i still dont get no shimmy on the highways my mag is straight but when i balance it it asks for 3oz on one side and 2 on the other with no Rim out of round on it so its my rims the problem think about it ,! my 2cents
porsche 944 1986 NA 8 valves 230k Kilometers on the clock weltmeister chip and coil springs , KYB gr-2 shocks all around , weltmeister throttle cam ! REbuilt head and all new sealed Upper motor ! fresh
Canada , Quebec
Old 09-23-2012, 11:10 AM
