SLED GUITARIST
Dan Himan's Avatar
Dropped cambridge in engine 16v
So my son dropped a 16v cambridge bolt in the #4 and 3 oil port, WTF. Do I remove head, I already remove the oil pan. The engine is on a stand.
1988 944S Guards Red---Hers FRWilks Chip, MSD Blaster 2
1987 944S Blue Diamond Mine Crankscapper, MSD Blaster 2 Coil, Weltmeister Race chip, Sports pack. Hit by a sleeping driver at 2pm, soon to be the Black and Tan
1985 944na Gray---His Eibach Gound Control Struts/Koni Rear, Throttle Response cam. SOLD
Old 03-13-2011, 06:33 PM
Pete R's Avatar
I hope your sons like 4 At least the motor is not in the car. Can you fish it out? I have a small eraser size magnet on a telescoping shaft. maybe turn the motor upside down on the stand see if it will fall out the way it went in. My last resort would be pulling the head. btw are you sure..just one bolt is in there?
1979 928 85 Euro 2v motor,S4 Brakes and suspension, 1988 951 street legal track car(sold)
Neon SRT4 track car
Old 03-13-2011, 06:42 PM
SLED GUITARIST
Dan Himan's Avatar
One bolt and maybe a very small magnet to try retrieving the bolt. It disappered.
Old 03-13-2011, 06:47 PM
ernie9944's Avatar
You migth want to try this type of magnet ,oppose to the telescopic this one is flexible. Good luck retrieving that bolt
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Old 03-13-2011, 07:42 PM
Pete R's Avatar
now I have magnet envy. that shop vac properly plumbed could work too
Neon SRT4 track car
Old 03-14-2011, 03:17 PM
Look on the bright side: You will now have a new head gasket and maybe a rebuilt head
Jackson
Old 03-14-2011, 04:28 PM
SLED GUITARIST
Dan Himan's Avatar
!@#$%^ bolt
I think I found the bolt in the center oil port. I might get a camara to view it, maybe get it out. I did find a cracked exhaust manifold.
Old 03-14-2011, 04:38 PM
SLED GUITARIST
Dan Himan's Avatar
After a couple of hours of trying different methods of bolt removal, i heated the area the bolt was at, and it finally gave. Then worked it out with a magnet and wire, nice and slowly. I will never forget to cover the oil ports again.
Old 03-14-2011, 07:34 PM
Porsche 944S Club Sport
guru944's Avatar
Send a message via AIM to guru944
Dan;
Happy to hear you got it out. A cracked manifold is common up to the later 88 cars including the 16V. I had a few in mine when i did my cylinder head work, including at the flange to the head. Had to TIG it myself but it worked out great. Recommend you do the same, Thermal wrap to minimize under-hood heat as well. Check out my Garage.
Got a Hypertech chip upgrade if your interested.
Keep us posted, Later...
Guru944
2006 955 Cayenne S Titanium Series - Marine Blue, 1987 Porsche 944S Club Sport.
1987 Buick Turbo-T Lightweight "Great White", +500HP, TA49 Turbo.
http://www.blackbirdmotorsports.com, 944/951/968, 911 and 955/957 Performance Solutions.
Thank you Lord, for your Loving Kindness, Tender Mercy, and Grace. Only You are Faithful.
Old 03-18-2011, 06:51 PM
SLED GUITARIST
Dan Himan's Avatar
Luckily I have a spare manifold. Nice S Guru. My 85 will need some work on the exhaust soon, as well as a tank repair.
Old 03-18-2011, 07:58 PM
