PorscheG96's Avatar
Send a message via AIM to PorscheG96
No Initial Cooling
My 968 no longer has operable initial cooling. There are two fans, one that operates once the temp. gauge reaches 9 o'clock [between 2nd and 3rd white bars] and another that comes on when temp reaches 3rd white bar or when AC is in use. The single fan no longer comes on when the temp. is between the 2nd and 3rd bars so the engine doesn't receive fan cooling until temp. reaches the 3rd white bar on the gauge. To avoid warm temperatures I just turn the AC on in town so that both fans run, and the temp. gauge indicates the second bar, which is perfect. No fan cooling is required on the freeway, temp. gauge reads 2nd bar, and the fan switch and fan relays have been replaced. What else could the problem be?
Old 02-10-2002, 01:40 PM
Roger Hall's Avatar
well your in good company there are alot of fan issues with water cooled porsches take two wires run them from the battery and connect them to the fan if it runs its good
Roger Hall
81 924 N/A
Some people are like Slinkies. Not really good for anything, but you
still can't help but smile when you see one tumble down the stairs.
Old 02-10-2002, 06:11 PM
PorscheG96's Avatar
The fan is good because they BOTH come on when the AC is turned on and when the secondary cooling is triggered. I'm not sure what the problem with initial cooling could be if the fan switch and relay are new.
Old 02-10-2002, 11:13 PM
Roger Hall's Avatar
you said the fan switch was replaced was it the thermo switch that is on the radiator
Roger Hall
81 924 N/A
Old 02-11-2002, 07:59 PM
PorscheG96's Avatar
Yup.
Old 02-11-2002, 08:32 PM
Roger Hall's Avatar
sounds like fan one is not getting power directly and only gets power from fan two never heard of this but i cant think of anything else are both fans supposed to come on with the a/c on my 81 924 only one fan comes on
Roger Hall
81 924 N/A
Old 02-12-2002, 08:40 PM
Roger Hall's Avatar
is it possible that the electrical wires are conected to the wrong fans
Roger Hall
81 924 N/A
Old 02-12-2002, 08:41 PM
Leadfoot's Avatar
check circuit diagrams, possible that power track is suppling both fans ..when cooling knob on console it switched on, relay is energised and power should flow...but you might have normally closed and normally open contacts on wrong connections....allowing power though continuously... what happens when cooling knob is turned on without ac?? see if power is going to relay, then check continuity of relay, see what connections it is currently on, might give u some clues as to where cooling power is being sent to.....Leadfoot
or find 968 owner and ask them where their connections are made and get diagram drawn...!! come on all u 968 owners...time to get busy with those pencils....
Old 02-14-2002, 02:58 AM
PorscheG96's Avatar
You sound like you're talking about the interior, LOL! The radiator cooling fans are what I'm talking about, not the climate control or cooling knob.
Old 02-14-2002, 11:00 AM
