James Chimney
cold air intake?
has any one used this it looks like it would pull the air from the fender well to this enclosed filter (no affiliation) 3" Yellow Adjustable Cold Air Intake+Filter+MAF Adapter - eBay (item 300537851067 end time Mar-24-11 14:37:10 PDT)
what do you guys think as my PO installed a cone filter, I have the air box but like the openness of the cone.
comes in 3 colors I have found so far on Ebay but $20 shipping? seems very high.
Old 03-21-2011, 02:35 AM
ernie9944's Avatar
Originally Posted by James Chimney View Post
has any one used this it looks like it would pull the air from the fender well to this enclosed filt.
I'll be standing by your window ,just open it and throw $40.oo out that will be $40.oo more in my pocketSeriously this is junk.
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Old 03-21-2011, 05:48 AM
Under the car
Agreed probably a waste especially if the inside of that tube isn't smooth. If it is ribbed along the length I would think the flow would be terrible.
Old 03-21-2011, 06:48 AM
Old Guy
sparky4017's Avatar
My 2 cents why would you want to hang a filter off a pipe out in the open because it looks cool
then put oil on the filter to fill the pipe with dirt and oil right into the AFS then to the TPS and into the motor good valve lube and then the water when it rains great for bending rods you now
have a 85hp Johnson outboard i raced motorcycles for 30 years been there done that
you could paypal the 40 bucks to me i could use the money on my Porsche not trying to be mean
I DON'T LIKE COLD AIR SYSTEMS
1963 Corvette 1969 Z/28 DZ 302 Silver & Black one owner me 1991 Mazda Miata 2011 F250 {work truck] 2011 Sicon
XB LE [Wifes Car] 1983 944 Slant Nose Wide Body [Mine]
Old 03-21-2011, 07:20 AM
James Chimney
Just thought I would ask, I have access to Stainless steel smooth wall flexible pipe 3" could I use this to relocate the "cone filter" to the wheel well, would this be better than the OEM?
or should i just re install the OEM air box with K&N filter and keep my $40 for the K&N?
thanks
Old 03-21-2011, 07:45 AM
Toofah King Bad
Rasta Monsta's Avatar
My 2.5 has a cold air intake from the fender, which is then routed through an air filter big enough for a V8. Can you guess where is was installed?
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 03-21-2011, 08:01 AM
ernie9944's Avatar
thanks
I know this is out of a 951, but if your a fabe guy why not try figure out something like this if you absolutely want a Cone Filter set up.
Old 03-21-2011, 08:07 AM
Proprietoristicly Refined
John_AZ's Avatar
Another good thread with some of ernies pictures...
But....from post 39 ......another idea.
Cold air intake?
John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 03-21-2011, 08:10 AM
porscha
matty89's Avatar
nice ernie! but the OEM filter piping is simply the best out there if ur a NA 944 .... it goes to the wheel well or very close to it ! why change it ? keep it stock is my 2cents
porsche 944 1986 NA 8 valves 230k Kilometers on the clock weltmeister chip and coil springs , KYB gr-2 shocks all around , weltmeister throttle cam ! REbuilt head and all new sealed Upper motor ! fresh
Canada , Quebec
Old 03-21-2011, 08:13 AM
John_AZ's Avatar
I give up.
Old 03-21-2011, 08:21 AM
James Chimney
doesn't the stock air box get its air from the fender?
I think I will just re install the stock air box and install a K&N filter
but I do like seeing what others have done.
James
Old 03-21-2011, 08:36 AM
John_AZ's Avatar
James
WAIT!
Search for K&N filter haters.
(I do have one and prefer paper)
John
Old 03-21-2011, 08:42 AM
Old Guy
sparky4017's Avatar
Ernie you have a neat set up most of what i see just hang out to the ellements
Old 03-21-2011, 08:52 AM
ernie9944's Avatar
____I know that Matty the pics send was meant to serve as an example,since James was asking for cone filter installation idea.
James
Best decision you will ever make reinstall the OE air box,until someone come up with a better idea.
Old 03-21-2011, 08:54 AM
Old Guy
sparky4017's Avatar
I'm not a k/n hater they make great products BUT oiled filters going through sensors don't work well after a while unless you clean alot
Old 03-21-2011, 09:01 AM
winter-hater club member
nynor's Avatar
factory.
"COOL PRIUS!" - Nobody Ever
Old 03-21-2011, 09:02 AM
ernie9944's Avatar
Sparky __This set up is not mine but of a 951 ,my car is a 968 with the (968 engineering mod air box (DIY) a K&N and a promax chip).Contrary to the 924S/944-S-S2 & 951 this mod on a 968 with the conjunction of what is mention above will conservatively net you approximately 10 to 15 more HP.The beauty of it is once done & the engine bay trims reinstall you can tell it's been done everything look original in there.
Old 03-21-2011, 09:45 AM
rickharrison's Avatar
Lindsey sells that very piece Ernie...its called a MAF Trap.
$89.95...well worth it in my opinion. (if you want that look)
MAF TRAP at LINDSEY RACING - Your Porsche Performance Parts Center
Rick Harrison
1988 944S
17 inch Cup 2's, euro bumper conversion
Magnaflow 2 1/2" exhaust with K & N 4 inch custom intake
MaxHP chipped
Old 03-21-2011, 10:06 AM
Toofah King Bad
factory.
Ding ding ding ding ding!
Old 03-21-2011, 10:19 AM
ernie9944's Avatar
LOL enougth talk and suspense pics are worth a thousand words "we are waiting" Rick___ agree on the Linsay racing Maf trap cause fabricating one migth be a bit of an hassle, beside your getting something that fit rigth .Any trip to the TIM lately with you car, up here still salt on the road snow banks are just starting to thaw.
Old 03-21-2011, 11:02 AM
