andrew4266's Avatar
Post replacing cat with glass pack
has anyone done this? it seems that it would keep it quiet yet still let the exhaust pass through.
Old 04-20-2001, 02:07 PM
wolfrpi's Avatar
Thumbs down
Sounds like it would make a pretty good fire under your car!
Erick
Old 04-20-2001, 02:28 PM
Post
I know of a 944T that has a hollow cat. It is only slightly louder than it was before the cat mysteriously lost its innerds. An NA would be louder but don't know how much.
Old 04-20-2001, 03:50 PM
1.2gees's Avatar
Send a message via AIM to 1.2gees
Post
An NA is really not that much louder, without a cat... However, if the muffler is stock, it may rattle a bit, as it has to a few on this board, including me...
Glasspack will NOT last long, in place of the cat. Instead, I'd suggest pulling out your stock downpipe, punching the cat, and installing it back. Be ready to replace your muffler as mine started making nasty noises after the track event.
Ahmet
It's all the driver...
Old 04-20-2001, 10:44 PM
porscha
matty89's Avatar
why wont the glass pack last long ? because of the heat? its made for heat no ?
porsche 944 1986 NA 8 valves 230k Kilometers on the clock weltmeister chip and coil springs , KYB gr-2 shocks all around , weltmeister throttle cam ! REbuilt head and all new sealed Upper motor ! fresh
Canada , Quebec
Old 03-13-2011, 02:55 PM
Redline Racer
HondaDustR's Avatar
It will help with flow but it doesn't sound good, but that also may depend on the exact glasspack you get,and your tolerance for 4 cyl rasp. I tried the 26" Thrush glasspack resonator and it may as well have been a straight pipe. Lots of harsh, raspy 4 cyl exhaust sounds made it through even the stock muffler. It sounded like a ricer on steroids with the thrush 2 chamber muffler...and so loud I had to swap the stock muffler on the next day (daily driver). I did run a punched out stock cat for a few months before that and it didn't increase the sound much with the stock muffler, but did sound slightly annoying for daily use with the 2 chamber. Keep in mind that changing the backpressure while running the stock chip can cause loss of low and mid range torque, which is what these engines really do best. The 944MAX chip I run is tuned for a test pipe, so I did notice some slight gains when running the empty cat and the glasspack, but the higher flow 2 chamber muffler I switched to seems to make it run better than stock even with the stock cat I am currently running.
The downside to a punched out cat is the weird pressure wave resonances that can get going inside the empty chamber and mess with the exhaust flow ( Good video explaination of this phenomenon here at 4:30 http://www.youtube.com/watch?v=Wa0BJqTG22Y&feature=channel_video_title ). The fiberglass packing in a glasspack burns out over time, especially with the cheaper brands. The factory cat is about half cat bricks, half glasspack resonator, so between the steel mesh liners left behind that support the cat bricks in the shell and the glasspack section, the hollowed out cat does a decent job of keeping the sound under control. The 944 motor is very large for a 4 cyl, being a 2.5L, and does make lots of undesirable 4 cyl type sound that has to be quieted down.
Play this vid in 720 HD mode for the best sound and you can hear some of the results of my last project. I do need to record how it sounds with the 2 chamber and the stock cat, ans I think it is the best of all of these. Skip to the 4:00 mark to get the audio answer to your question.
YouTube - Porsche 924S Thrush exhaust project
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky
Old 03-13-2011, 07:51 PM
"Dude! You kicked my car.
Rudeboy42's Avatar
Whatever you do definitely don't put a Bursch header and test pipe with nothing but a cherry bomb glasspack.
God what the hell was I thinking?
Old 03-13-2011, 10:00 PM
CKniht90's Avatar
Send a message via MSN to CKniht90 Send a message via Yahoo to CKniht90
Rudeboy.. got pictures or video?
88 944 2.5L 4cyl NA Zermatt Silver CE - Daily Driver - SOLD
Old 03-13-2011, 11:43 PM
porscha
matty89's Avatar
right now im running a straight pipe cat tube and my muffler nest is starting to make a metal noise so i think all put a MFlow highflow cat(90$) and a Mflow muffler(100$ ) but im still debating on what to do ! suggestions ?
Canada , Quebec
Old 03-14-2011, 07:39 AM
ernie9944's Avatar
Butting in with my combo (which will last -give you good service & will produce a deep throaty sound ) was install on my 944 quiet a few years back. S/S cat mode to fit ,dumping in the OE muffler with a 4" S/S polish exhaust tip.Glass pack do yourself & your car a favour keep away from it.
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Old 03-14-2011, 08:57 AM
porscha
matty89's Avatar
where di you get ur SS cat or resonator it looks like to me ?
Canada , Quebec
Old 03-19-2011, 04:35 PM
ernie9944's Avatar
This not a resonator it's a s/s cat got it at my local speed shop.
Old 03-19-2011, 04:48 PM
porscha
matty89's Avatar
do you remember off hand how much it was like 100$ or 200$ i dont know if im going to leave my cat without the cat or not muffler is ratteling a little inside of it .... im thinking of a cat like urs or a resonator with a new muffler depends on the prices i get off with..
Canada , Quebec
Old 03-20-2011, 07:26 AM
ernie9944's Avatar
Matty___ this install was done I believe 8 or 9 years ago ,when my cat when nuke I started looking around for another one but didn't want to go OE ,so this guy at the speed shop had that one that someone order for a Honda.I beleive the price was around $200.oo but since it was laying around I got it for $80.oo brand new in the box,like said I had to modified it a little by using the flange on my old cat .As far as the part number is concern I don't have it and the box is long gone ,so not much help there,one thing I remember is that it had two outlet plugs on the top (front) .After the install I kept a close watch on it for adverse effects on the car performance but found none in fact it seem to work better then the OE one ,with the add of the 4" tip the car had a nice throaty sound but nothing (extreme or ricy) .It's still on the car after all them years & just doing find.You can call it (trial & error) sort a thing just happen to be lucky it did work I guess. If your's is giving up why don't you look around for an after market one ,they are some nice one out there that doesn't cost a fortune & do the job just fine.
Old 03-20-2011, 08:28 AM
ernie9944's Avatar
Matty--- two exemple of what is out there, those are S/S Pace Setter cats__ first one is approx $160.00___ second $125.00,if you do buy one don't buy the cheap one at $40 or $50 they won't last. The first one you would probably have to do the same mod as I did to install, cut the flanges on your OE cat and re-weld them but any good muffler shop can do the install properly.
Old 03-20-2011, 09:00 AM
When I bought my 944 it had the header, test pipe, and stock catback and had the rattling that everyone talks about. So I installed some no-name dual outlet muffler that I inherited with the car and it was loud as hell. Then I got a Thrush glass pack to put in place of the test pipe. It quieted down considerably and is tolerable now. As far as the heat/fire, yeah it looks like it got hot down there. The paint is fried off of the last 3 inches of the glasspack. I've done about a dozen track days with it and haven't had any issues with the heat though.
Old 03-20-2011, 03:25 PM
Back from Beyond
Hmmm... How about getting a stock 944 Euro resonator from a breaker in...well...Europe?
'88 944 Auto - project, kinda
'87 944 Auto - died saving my wife
'84 944 5SP - crushed under shop roof during snow storm
All others GONE!
Old 03-22-2011, 09:16 AM
Redline Racer
HondaDustR's Avatar
Someone did that a little while ago. The big challenge is that the y-pipe flanges are oriented differently, requiring cutting and rewelding so the screw holes line up with the non-euro headers. It probably sounds and performs the best, though.
Old 03-22-2011, 10:54 AM
Back from Beyond
Come to think of it, I recall seeing that thread. I think the upshot was that you'd have to get the exhaust mani with the resonator.
My 83 has a resonator, and the car's loud but it sounds good. My 84 with the sotck setup is quieter but doesn't have the same snarl on decel over-run. My wife;s 924 has a straight pipe to the muffler, and it sounds very nice indeed.
All others GONE!
Old 03-23-2011, 09:29 AM
