P944GUY's Avatar
Euro side repeater lights
Anyone installed euro side repeaters on their car
got a nice set of euro side repeater lights and lenses set up, including the wiring harness to the ligths..Does anyone know if the connector to the wiring harness is up under the dash, it's just a 2 prong connector, like one in the rear tailights area..was not sure if they incorporated some of the euro light connectors into the US harness..would be a plus if they did..haven't had a chance to get int here and check..
Beer Cigars and a 10mm socket...
Old 03-25-2011, 09:25 PM
I am about to do the same, since these lamps are legal requirement here in Europe and I have a car imported from the US, so I would also be very interested in the solution. Looking at the wiring diagrams, it does seem like the side repeaters may be connected to the wiring going to the rear, which may or may not be logical.
Old 03-26-2011, 02:26 AM
I have done some investigations (this is for a LHD vehicle).
On the RH (passenger) side there is a cable going to the ABS actuator located in the wing (fender), so it is easy to route the cable to inside the passenger compartment along the same path. However, the wiring for the main indicators seems to be located only on the driver's side, so the wiring needs to be routed also from the RH to the LH side of the dashboard.
On the LH side, for a similar arrangement, a hole needs to be drilled in a similar location as the existing hole on the RH side, with suitable rust protection and grommet.
Alternatively, on both sides, the cable can be routed from the side repeater to the front indicators over the wheel, and join it there. A challenge may be how to best secure the cable, I really want to avoid drilling holes here. Also, the wiring is somewhat more exposed to the elements, but would be protected behind the inner liner.
Old 03-30-2011, 11:56 PM
I ended up using this solution for both sides. On the RH sides there are two studs that makes it possible to secure the cable fairly well.
Old 04-10-2011, 11:06 PM
89-944NA's Avatar
Location: In a dumpster behind Albertson's in Los Angeles County
Send a message via Yahoo to 89-944NA
No, it does not look as though the US model has the connectors for the Euro side repeater lights.
US chassis harness is P/N: 951.612.006.01 (85.5) 006.05 (86) 006.10 (87) 006.19 (88) 006.34 (89-91)
Euro Chassis harness is P/N: 951.612.006.00 (85.5) 006.04 (86) 006.09 (87) 006.18 (88) and 006.28 (89-91)
1989 944 NA Glacier Blue - SOLD IT
1989 944 S2 Alpine White T-Boned (totaled) by a lady dressed in a CLOWN costume (RIP ) Apr 89 - Mar 08
1988 944 Turbo S Silver Rose Metallic, K27/6, Vitesse MAF, Tial 38mm DP WG
Semper Fi
Old 04-10-2011, 11:51 PM
All Spooled Up
Pardon my ignorance, but what exactly are "repeater" lights? I've never heard the term.
Are they the kind of turn signal indicators that that have several sections which light up in sequence, starting from the inside, working their way to the outside?
>gray 89 951S - K27/8, MAF, 3" intake, 3" exhaust w/separate waste pipe, 55# inj, late cam; >red 87 924S - chip, K&N, punched-out cat&muffler >black 80 924 - (sold) >maroon 77 924 - auto (sold)
Old 04-11-2011, 04:13 AM
Nothing fancy, just an extra indicator on the side of the vehicle, as required in Europe after approx 1970:
Old 04-11-2011, 05:04 AM
All Spooled Up
Is there one in the rear as well?
Old 04-11-2011, 05:14 AM
Hellraiser's Avatar
Send a message via MSN to Hellraiser
No.
Old 04-11-2011, 05:35 AM
