-   -   924 Ignition issue... Thoughts? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/599992-924-ignition-issue-thoughts.html)
jonjchris 03-30-2011 06:18 AM
I need a second opinion. I have a 78' 924 that has been parked for the winter. I just drove it home a few days ago and now the car won't start/ stay running.
I am thinking it may be the ignition switch behind the key tumbler. When I turn the key to the run position, only my stereo comes on. I believe it should turn all of the gauges on as well. When I turn the key to start the car, it will turn over and start, but as soon as I release the key it dies.
Also is this switch easy to replace?
Is this a reasonable explanation to my problem? Please give me your thoughts and opinions!
Rasta Monsta 03-30-2011 08:02 AM
Switch is dirt cheap and easy to swap. Your diagnosis sounds correct.
jonjchris 03-30-2011 08:53 AM
How the heck do I get the switch out of the dash? I can't see what is holding it in
Rasta Monsta 03-30-2011 09:51 AM
Have you got a manual?
jonjchris 03-30-2011 10:11 AM
Yes I have a haynes. I also just found some help on 924.org.
924.ORG FAQ
