Jon C
jonjchris's Avatar
924 Ignition issue... Thoughts?
I need a second opinion. I have a 78' 924 that has been parked for the winter. I just drove it home a few days ago and now the car won't start/ stay running.
I am thinking it may be the ignition switch behind the key tumbler. When I turn the key to the run position, only my stereo comes on. I believe it should turn all of the gauges on as well. When I turn the key to start the car, it will turn over and start, but as soon as I release the key it dies.
Also is this switch easy to replace?
Is this a reasonable explanation to my problem? Please give me your thoughts and opinions!
Old 03-30-2011, 06:18 AM
Toofah King Bad
Rasta Monsta's Avatar
Switch is dirt cheap and easy to swap. Your diagnosis sounds correct.
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 03-30-2011, 08:02 AM
Jon C
jonjchris's Avatar
How the heck do I get the switch out of the dash? I can't see what is holding it in
Old 03-30-2011, 08:53 AM
Toofah King Bad
Have you got a manual?
Old 03-30-2011, 09:51 AM
Jon C
jonjchris's Avatar
Yes I have a haynes. I also just found some help on 924.org.
924.ORG FAQ
Old 03-30-2011, 10:11 AM
