SLED GUITARIST
Dan Himan's Avatar
944S Compression/Resurfaced head
What is the normal and/ or new compression lbs for a 1987 944S 16valve, and what would happen if you use a regular H/G with a resurfaced head?
1988 944S Guards Red---Hers FRWilks Chip, MSD Blaster 2
1987 944S Blue Diamond Mine Crankscapper, MSD Blaster 2 Coil, Weltmeister Race chip, Sports pack. Hit by a sleeping driver at 2pm, soon to be the Black and Tan
1985 944na Gray---His Eibach Gound Control Struts/Koni Rear, Throttle Response cam. SOLD
Old 04-11-2011, 06:08 PM
89-944NA's Avatar
Location: In a dumpster behind Albertson's in Los Angeles County
Send a message via Yahoo to 89-944NA
Compression Ratio is 10.9:1, and if you are using the Victor Reinz head gasket, all they pack in there sets anymore are the "turbo" gasket...no issues with that gasket.
A quick check of the Porsche PET lists the "turbo" gasket P/N 951.104.374.50 for ALL resurfaced heads (including the M44.40 16 valve head)
1989 944 NA Glacier Blue - SOLD IT
1989 944 S2 Alpine White T-Boned (totaled) by a lady dressed in a CLOWN costume (RIP ) Apr 89 - Mar 08
1988 944 Turbo S Silver Rose Metallic, K27/6, Vitesse MAF, Tial 38mm DP WG
Semper Fi
Old 04-11-2011, 07:03 PM
compression test numbers? or actual compression ratio?
compression test numbers depend on alot of things, the two biggest are altitude and the weather. as long as all 4 are within 10psi, that's "good"
Old 04-11-2011, 07:04 PM
SLED GUITARIST
Dan Himan's Avatar
Compression test numbers. My spare 16v head looks like someone cleaned it up some. I can see the machining on the mating surface to the block. Looks flat with a long square. I was looking for the measuring mark and numbers for the head. I saw it some time ago but can not find.
Old 04-11-2011, 08:43 PM
