Self-Proclaimed Newb
Brozoar's Avatar
Send a message via Skype™ to Brozoar
Rusty Old Rockers
So the other day, I emerged from a store with my g/f; I shall not say which, suffice it to say, it starts with a "Victoria's" and ends with a "Secret". Anywho, as soon as I got to my car I found there's a brand-spankin' new rusted-out hole towards the back of the driver's side rocker.
Is there any good literature out there on removing and replacing the stock rockers? I was thinking of going with some fiberglass aftermarket ones from GT-Racing. But it looks like they span from the front all the way to the rear tire. Meaning I have to do some modification to my body (i.e. sawing a small section off) to fit them...????
Is this a doable job, or should I seek professional help?
Current: 1986 944 Turbo - Sapphire
Past: 1983 944NA - Black (RIP)
1985.5 944NA - Guards Red (in purgatory)
1985.0 944NA - Maraschino Red (traded for a Volvo 244 )
Old 05-01-2011, 04:18 PM
Proprietoristicly Refined
John_AZ's Avatar
"Rusty Old Rockers"
Oh, I thought you were talking about Alice Cooper
DNK (Do not know)
John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 05-01-2011, 06:34 PM
"THERE IS NO SUBSTITUTE"
mayPOR944's Avatar
rust? no such thing, so wierd hearing all of these 944 rusting, 25 pounds of under coating plus galvanized plus zinz coated weird, must start with a rock chip or somthing.
1986 Porsche 944 2.5
2004 Jeep Grand Cherokee Limited 4.7 H.O.
2000 Plymouth Neon
Old 05-01-2011, 08:57 PM
Rocket Surgeon
Pettybird's Avatar
Send a message via AIM to Pettybird
that'll teach you to shop at victoria's secret.
'89 951S, Velvet Red
Plymouth Superbird, Corporation Blue
Plymouth Superbird, Blue Fire Metallic
Old 05-02-2011, 02:29 PM
Brozoar's Avatar
^Lol, gift card. I know mate, I don't get it...
Michigan roads probably don't help, but yeah, it is weird. Those things are deteriorating pretty quickly; it's a real pity, because otherwise the body's pretty straight. Maybe someone sanded away at the zinc when they painted it black?
How are the sunroof drainage hoses set up on these cars? I read something here that makes me think that could be related to my issue. I think galvanized steel is basically just steel that's been zinc-coated, so I guess if the inside isn't galvanized, water draining out there could rot out the panels from the inside. Pure speculation on my part.
Old 05-02-2011, 11:16 PM
Brozoar's Avatar
Bump... Anyone else's rockers rusting? :/
Old 05-05-2011, 02:25 PM
Dog-faced pony soldier
Porsche-O-Phile's Avatar
Grind off all the paint and bumpy/textured coating stuff. Determine the full extent of the rust.
Get a dremel or cutting wheel.
Remove COMPLETELY all of the rusted section plus 1-2". Throw it in the nearest dumpster.
Get replacement sheet metal, cut to size, tack weld onto body. Apply filler and/or seam sealer as required, prime and paint.
That's the ONLY way to deal with rust. It's a cancer. Cut it out and kill it. Do it now.
Black Cars Matter
Old 05-06-2011, 07:01 AM
Parrothead member
VINMAN's Avatar
Yep. have the same exact problem. Currently doing what POP said in the above post. Noticed I'm starting to get a little on the passenger side now.
Vinny
Old 05-06-2011, 07:16 AM
