77, 924, compression
Hi. the compression on the 4th cylinder is 60 psi, and the other 3 are at 120.
it idles roughly and stalls sometimes. should i change the valvles? wires, cap, etc. are all new. |
You could check the valve clearances, but most likely it needs a headgasket and valve job while you're in there.
A leakdown test will also provide more information to confirm valves, etc.
Vaughan Scott http://www.vaughanscott.com http://www.924.org |
that's what we're doing today.
thanks a lot bud |
Tags |
1977 , 924 , low compression , porsche , rough idle |
