-   -   a/c relay troubleshoot (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/608918-c-relay-troubleshoot.html)
joe hockin 05-15-2011 07:32 PM
should one be able to jump the terminals on the compressor relay? Providing 12 v to the central terminal engages the compressor clutch...but there isn't 12 from any of the pins under the relay...is the juice from the control unit? Confused
rb101 05-16-2011 06:10 AM
The power goes from the fuse to the a/c control unit to the a/c relay.
bazar01 05-16-2011 12:57 PM
Check for proper charge, the system might be low on charge causing the low pressure switch to open not passing 12V to the clutch.
mattdavis11 05-16-2011 04:33 PM
There could be other problems too. What year is the car?
joe hockin 05-16-2011 05:43 PM
944 ac
It is an '85.5 944. I checked the control unit...seems ok...no matter what I do no juice at the clutch. Pressure switch is bridged. When the central pin of the relay is energized it sends power to the clutch...and th fuse is good.
mattdavis11 05-16-2011 06:13 PM
Do the later cars have an a/c amplifier? The early car does and it's the source that sends power to the compressor clutch.
rb101 05-17-2011 06:04 AM
From the relay power goes directly to the clutch. Are you getting power to the relay from the control unit?
joe hockin 05-17-2011 09:32 AM
a/c power
Hi,
There isn't any power at the relay...it doesn't trip when the switch is thrown and there isn't a hot to jump to the centre pin. The control unit has power...atleast everything else opperates
mattdavis11 05-17-2011 05:36 PM
I'm not savvy enough to load a picture, but if someone can load the schematic here in the form of a picture, I can show you where I'd suspect the problem is.
joe hockin 05-18-2011 12:39 PM
Hi,
Could you describe it to me ...the contol unit seems fine...just no 12 v at the relay.
mattdavis11 05-18-2011 03:49 PM
On the diagram in the FSM there is a power distribution block for most everything a/c. Right below it in the picture you'll find "Cooling Fan" next to it G10. I assume G10 is hot. Any way from what I traced, the control unit can be hot while the compressor and other related items are not.
