a/c relay troubleshoot
should one be able to jump the terminals on the compressor relay? Providing 12 v to the central terminal engages the compressor clutch...but there isn't 12 from any of the pins under the relay...is the juice from the control unit? Confused
Old 05-15-2011, 07:32 PM
The power goes from the fuse to the a/c control unit to the a/c relay.
Rick
99 996C4
06 525XI
87 944S - Sold
77 924 - Sold
Old 05-16-2011, 06:10 AM
Check for proper charge, the system might be low on charge causing the low pressure switch to open not passing 12V to the clutch.
1993 964 C2 still makes me smile
Retired and work as needed as a pain in the **s.
Old 05-16-2011, 12:57 PM
Just thinking out loud
mattdavis11's Avatar
There could be other problems too. What year is the car?
91 FJ80
84 Ram Charger (now gone)
Old 05-16-2011, 04:33 PM
944 ac
It is an '85.5 944. I checked the control unit...seems ok...no matter what I do no juice at the clutch. Pressure switch is bridged. When the central pin of the relay is energized it sends power to the clutch...and th fuse is good.
Old 05-16-2011, 05:43 PM
Do the later cars have an a/c amplifier? The early car does and it's the source that sends power to the compressor clutch.
91 FJ80
Old 05-16-2011, 06:13 PM
From the relay power goes directly to the clutch. Are you getting power to the relay from the control unit?
Rick
99 996C4
06 525XI
87 944S - Sold
77 924 - Sold
Old 05-17-2011, 06:04 AM
a/c power
Hi,
There isn't any power at the relay...it doesn't trip when the switch is thrown and there isn't a hot to jump to the centre pin. The control unit has power...atleast everything else opperates
Old 05-17-2011, 09:32 AM
I'm not savvy enough to load a picture, but if someone can load the schematic here in the form of a picture, I can show you where I'd suspect the problem is.
91 FJ80
Old 05-17-2011, 05:36 PM
Hi,
Could you describe it to me ...the contol unit seems fine...just no 12 v at the relay.
Old 05-18-2011, 12:39 PM
On the diagram in the FSM there is a power distribution block for most everything a/c. Right below it in the picture you'll find "Cooling Fan" next to it G10. I assume G10 is hot. Any way from what I traced, the control unit can be hot while the compressor and other related items are not.
91 FJ80
Old 05-18-2011, 03:49 PM
