SLED GUITARIST
Spun Bearing Pics
I finally got around to dis-assemble my spare engine, and as i suspected, spun #2 bearing.
![]() ![]() ![]() I was really happy to find my cylinder walls are still in good shape. The question is how to proceed? I know I need to have the crank checked. Do I have the rod resurfaced? I realize that I will need an oversized bearing, can I just do the one rod?
1988 944S Guards Red---Hers FRWilks Chip, MSD Blaster 2 1987 944S Blue Diamond Mine Crankscapper, MSD Blaster 2 Coil, Weltmeister Race chip, Sports pack. Hit by a sleeping driver at 2pm, soon to be the Black and Tan 1985 944na Gray---His Eibach Gound Control Struts/Koni Rear, Throttle Response cam. SOLD
SLED GUITARIST
What is a crossed drilled crank, any pics? I read that the crank scrapper helps avoid this spun bearing issue. Is this correct? I did install one in my 87 S. I did not have the money to get the tray. The crank seems to spin fine with no play, is it possible to reuse the main bearings (not the rod bearing)?
Desertt5
Subscribing. I am sure I lost or am about to lose #2. Comp check read only 80psi or something like that. I only have the head off so far. Cylinder walls look good too. Head at the shop being checked out as of today. Not sure what I am going to do with it. The rest of it is getting parted.
Semper Fi |
I would take the crank out and have it magnafluxed, measured and polished. You could bring the con rod to whoever does your crank and have them look at it. It's so torn down now, not doing main bearings is not very cost effective. It may has well all be fresh. A cross drilled crank reroutes the oil passage so it flows easier to the #2 bearing at high rpms.
1979 928 85 Euro 2v motor,S4 Brakes and suspension, 1988 951 street legal track car(sold) Neon SRT4 track car |
Proprietoristicly Refined
Pics:
Rennlist Discussion Forums - View Single Post - Re-ring question for the guru's More info Member Dare rennlist (his pic link also) The following post contains a very helpful picture of a 928 crank that has cross drilled oil passages in both the main and rod bearings. Although a 928 crank is considerably different from a 944 crank, I think the picture does a good job of illustrating the routing of oil passages in a crankshaft and the concept of crossdrilling. http://forums.rennlist.com/rennforums/3855652-post10.html On the 944 crank the main bearings are all cross drilled. However the rod bearings are only 'half-drilled'--i.e. the passages don't go all the way through. Cross drilling the crank involves drilling the rod oil passages through to the other side of the journal and chamfering the edges of the new oil feed hole. Typically this is only done on the #2 and #3 bearings. __________________ Jay John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo) Last edited by John_AZ; 05-23-2011 at 09:13 PM.. |
Crank scraper keeps oil in the pan. Thus making the pump less likely to starve. For sure helps prevent bearing failure. This also frees up hp because the crank isn't carrying that extra weight. Cross drilling also helps oiling. Windage tray will help cut down on oil in suspension and free up even more hp. These are all positive things. I would ditch the cross drill but do the windage tray and scraper.
82 928 s3&1/2 5 Speed LSD conversion 87 944 N/A 5 Speed (Under Construction) 81 931 (maybe for sale, well their all for sale lol) Always looking for a good deal. Hello, my name is Carl and im a Poschaholic Last edited by vdubr928; 05-23-2011 at 09:45 PM.. |
No. You can't just do one. Maybe you can but really bad idea. Keep it simple. The crank will need to be polished at least.
82 928 s3&1/2 5 Speed LSD conversion 87 944 N/A 5 Speed (Under Construction) 81 931 (maybe for sale, well their all for sale lol) Always looking for a good deal. Hello, my name is Carl and im a Poschaholic |
That Guy
Personally, with the amount of used parts floating around for these cars i would replace the crank with a used one (all 2.5L cranks are the same and dime a dozen) and find yourself a spare 16v rod. By the time you factor in the cost of machine work for your damaged parts and the cost of oversized rod bearings (about $100 each from Porsche) i think its more worthwhile to go this route.
You should take the girdle off anyhow to flush out the oil passages aswell as the oil cooler. You dont need to replace the mains but with the girdle already off you are only $180 away from replacing them. What is your intended use for this motor when you get it running? If this is strictly a street engine i would save the money and only baffle the pan and replace the pickup tube. Even if you intend to track and want to do this on a relative tight budget, i would go crank scraper and crossdrill at most. The windage tray from IJ is not cheap.
Jon 1988 Granite Green 911 3.4L 2005 Arctic Silver 996 GT3 Past worth mentioning - 1987 924S, 1987 944, 1988 944T with 5.7L LS1 Last edited by Techno Duck; 05-23-2011 at 10:20 PM.. |
True. I probably have some stock rods.
btw, what oil have you been using?
Patrick Youtube 333pg333 86 modified 951 |
remember when u put it back together that the girdle surface needs to have sealant applied before bolt it back together. AND the front need to have sealed too before the oil pump goes on. that cost me a boatload of hassle and a trip to the shop.
when i had mine apart, i crossdrilled #2 and #3, polished, new rod bearings, new rod nuts (important!), new mains, new pilot bearing, new front main seal, new rear main seal. do it all while it's apart. my oil pan was already baffled, pickup tube already reinforced. |
SLED GUITARIST
I purchased the 87 S with a seized engine, and just replaced. I plan on rebuilding the spare just for street. I definitely want the engine to perform and last. Replacing the crank and rod sound like the way to go. Scraper and tray install for sure. The cross drill seems like it could compromise the crank.
The 88 S might need rings and rod bearings, still runs strong, I might replace with engine in place. I don't know, maybe wait till the replacement engine is done. It sure is nice to have options thou.
SLED GUITARIST
I would need the 1 S rod, right (higher compression)? The other 3 look good. I did notice the numbering on the parts, all 86. I am going to do some measuring tonight.
Thanks everyone for chiming in.
