Will program for food
ghnat's Avatar
Need some belt help
Well, car started to overheat and pulled over and shut off the engine. Had the car towed home and the tow truck guy messed up my rear brake line, I think. either that or it just happened to break. I changed them less than 3 years ago. But that is another story. The engine was making a weird whining, above the normal belt whine.
I took off the belt cover and this is what I see:
I had the belts replaced about 3 years ago and they were just re-tensioned about 2 weeks ago. Not sure if the tension roller was replaced, but if not then I need to now.
Now I can feel a slight groove on the flat side of the belt going to the water pump.
Do I just replace the roller and if so can I do it without removing the belts?
Greg Hnat
87 Targa Disassembled
90 944 S2 Auto-x, DE and semi-daily driver
98 Jeep Cherokee
Old 05-31-2011, 07:00 PM
That Guy
Techno Duck's Avatar
That is the idler pulley, the tension roller is under that.
The bearing in it probably seized.. if the other rollers (timing and balance belt tensioner, balance idler) were not changed they should be replaced also.
Replace the belts also.. reusing is asking for trouble.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 05-31-2011, 07:47 PM
ghnat's Avatar
Thanks Techno Duck..
I was going to get all new rollers, just was not sure of the belts since they have ~20k on them.
Any suggestions on the best belts to buy? Gates or Contitech or ???
Greg Hnat
98 Jeep Cherokee
Old 05-31-2011, 09:13 PM
That Guy
Everyone has there opinion on it, i have used Contitech and the Porsche branded Gates belt and really have no preference. There were one or two posts not long ago about problems with the Contitech belts but one has to wonder the circumstances around that like how old the belts were sitting on shelf, tension correct, condition of everything else..etc.
The Contitech and Gates aftermarket are like $15 where as the Porsche branded Gates belt is under $40. I used the Conti belt on my last two belt jobs and when i did my belts earlier this year i used the Porsche branded Gates belt.. i would use either, it basically just comes down to brand preference.
Jon
Old 05-31-2011, 09:35 PM
Duck's right, conti is fine. I've put them on about a dozen race cars and have been using them on my street car for 16 years. A belt that's been rubbing on a seized roller has been compromised and probably won't last long. Definitely replace it, it's cheap anyway and you're already in there.
Old 05-31-2011, 11:11 PM
89-944NA's Avatar
Location: In a dumpster behind Albertson's in Los Angeles County
Send a message via Yahoo to 89-944NA
I have used Conti for years on both daily drivers and race cars, never had a problem (recently changed to the Gates Kevlar on race cars though, just for extra insurance).
If that is your S2, Pelican has a complete kit, both belts, 2 tension rollers and 3 idler rollers for $319.50.
1989 944 NA Glacier Blue - SOLD IT
1989 944 S2 Alpine White T-Boned (totaled) by a lady dressed in a CLOWN costume (RIP ) Apr 89 - Mar 08
1988 944 Turbo S Silver Rose Metallic, K27/6, Vitesse MAF, Tial 38mm DP WG
Semper Fi
Old 06-01-2011, 05:17 PM
