Bellhousing and torque tube issues
Well I have a track event this coming weekend and my '83 decided to leak from the rear main seal. So I am scrambling to correct that as well as everything else while I am in there. Two issues I am stuck on :
1) The upper drivers side bolt on the bellhousing is hard to get at and I could not budge it. What's the trick to get this one off?
2) My torque tube has been making the coffee grinder sound when I let off the gas so I thought I would rebuild it also. After getting it off and spinning the driveshaft the bearings are quiet. Is that a proper test, is a bearing still bad ?
Old 06-19-2011, 08:43 PM
1. With the torque tube out of the way, you can drop the bell housing end of the engine and gain more space up there.
2. Grinding noises on decel is not a TT bearing issue, it is more like a transaxle pinion bearing issue.
1993 964 C2 still makes me smile
Retired and work as needed as a pain in the **s.
Old 06-20-2011, 02:27 AM
ernie9944's Avatar
BTW if not done yet you should notch the bell housing ,will save you a lot of hassle.
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Old 06-20-2011, 05:55 AM
Proprietoristicly Refined
John_AZ's Avatar
#1
Either get 2 feet of extensions an a universal with socket or get the correct universal socket.
#2
There are 4 bearings inside the TT.
Here is the procedure---not a 2 hour job...Many DIYs in the forums.
Torque Tube Removal, Rebuilding, and Installation
3,4,5,6,7 Oil the RMS lips and crank shaft or the RMS will burn out.
GL
John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 06-20-2011, 06:36 AM
I think lowering the engine will help me out. I wondered why it needed supporting anyway when it should be able to sit on the crossmember just fine. No need to notch bell housing as the sensors dont scare me anymore. I can do that in 15-20 mins now I have done it so much. Rachet head socket wrench did the trick for me. Transaxle pinion bearing sounds like no fun. Aren't there about three in there ? Any way to verify while I have it out ? I talked to a local P-car shop and he said the TT sounded ok to him also and thought it was likely a clutch bearing.
Old 06-20-2011, 12:23 PM
Custom User Title
mikepellegrini's Avatar
You hit the nail on the head. Lowering the engine a bit will make the bolt accessible.
Notching the bellhousing is a really good idea, and it'll make it easier to do the clutch in the future. It'll save at least that 15-20 minutes, unless of course a sensor gets stuck, cause then pulling the buggers out can take a lonnnnngggg time... Notch it - you won't be sorry.
83 944 NA - Black on black
86 951 - Red - SOLD 7/21
16 Ford Expedition
He who hesitates is lost.
Old 06-20-2011, 05:53 PM
Yeah I hink I will take the time to do that. Should not take long to notch. One of the PP bolts stripped , this car has fought me all he way. I guess I have to drill the head off. Joy.
Old 06-21-2011, 06:02 AM
John_AZ's Avatar
I "notched" the bell housing on my '87.
I decided not to on my '88 after I found the TSB below. I do not have any hard start symptoms on either car. The "sheilding sleeve" was designed to prevent starter electromagnetic interference.
The preferred design is to have/keep the "holes" and not the slot. YMMV --Your choice.
S2 and 968 speed reference sensor question
GL
John
Old 06-21-2011, 07:56 AM
Did not know that John thanks. I thought later cars had the notch anyway ? So for those that notched is anyone having issues John mentioned ?
Old 06-21-2011, 12:53 PM
