-   -   944 Cabriolet MOD all cab's need. (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/615760-944-cabriolet-mod-all-cabs-need.html)
Dawgz83948 06-24-2011 11:13 AM
As you all know the 944 and 968 cabriolet have an electric pop mechanism for the trunk. Porsche got their head out of their butt with the 968 and made an emergency release for if/when the electric system fails. Unfortunately for us 944's do not have this, however this is what I did. Maybe this will help some of you do make an emergency release.
Remove the latch.
http://i824.photobucket.com/albums/z...8/IMAG0231.jpg
Remove the round pull out of it's holder. As you can see it has a hole through it, if it doesn't go through drill it out the rest of the way. I had 2 latches, the original 90 had a hole through it, the 89 did not.
http://i824.photobucket.com/albums/z...8/IMAG0230.jpg
I ran 18 gauge wire through the hole, put a round crimp on connector on the end and put the round pull thing back on it tight (it acts as a pinch).
http://i824.photobucket.com/albums/z...8/IMAG0226.jpg
Routed the wire like the next coupel wires.
http://i824.photobucket.com/albums/z...8/IMAG0227.jpg
http://i824.photobucket.com/albums/z...8/IMAG0228.jpg
You'll need to use a fish to get the wire through the reinforcements.
http://i824.photobucket.com/albums/z...8/IMAG0229.jpg
Proof of concept.
948 :: VIDEO0008.mp4 video by dawgz83948 - Photobucket
ENJOY
alfadoc 06-24-2011 01:03 PM
Pininfarina bodied cars (Fiat, Alfa, Ferrari) started this feature for hood and trunk back in the mid-late 60's. Good idea for your Cab!
Dawgz83948 06-26-2011 07:21 PM
It only took Porsche 3 years to figure out that was a bone headed move since they rectified it on the 968.
Catamax944 06-27-2011 01:19 AM
why not open it with the key ?? is it different from the coupe ? I always open mine with the key,the cable from the motor to the latch snapped and i never replaced it infact i also took the motor out for good when i did some weight reduction.
Dawgz83948 06-27-2011 06:24 AM
Because all the key does is turn a cam that activates a microswitch which toggles the motor to pop the trunk. There is no mechanical connection to the latch from the key cylinder.
egil 06-27-2011 07:29 AM
From the pictures, I assume the emergency release on the 968 is behind that plastic grille in the door opening on the driver's side?
Dawgz83948 06-27-2011 07:33 AM
On the cabriolet's only, that's what I hear. I haven't had the opportunity to look, but a good source told me this was the case.
