Dawgz83948's Avatar
944 Cabriolet MOD all cab's need.
As you all know the 944 and 968 cabriolet have an electric pop mechanism for the trunk. Porsche got their head out of their butt with the 968 and made an emergency release for if/when the electric system fails. Unfortunately for us 944's do not have this, however this is what I did. Maybe this will help some of you do make an emergency release.
Remove the latch.
Remove the round pull out of it's holder. As you can see it has a hole through it, if it doesn't go through drill it out the rest of the way. I had 2 latches, the original 90 had a hole through it, the 89 did not.
I ran 18 gauge wire through the hole, put a round crimp on connector on the end and put the round pull thing back on it tight (it acts as a pinch).
Routed the wire like the next coupel wires.
You'll need to use a fish to get the wire through the reinforcements.
Proof of concept.
948 :: VIDEO0008.mp4 video by dawgz83948 - Photobucket
ENJOY
Old 06-24-2011, 12:13 PM
ASE Master
alfadoc's Avatar
Pininfarina bodied cars (Fiat, Alfa, Ferrari) started this feature for hood and trunk back in the mid-late 60's. Good idea for your Cab!
1989 944S2 (sold after 11 great years)
1980 911SC Weissach (bucket list car)
1975 914 1.8 (future restoration)
1993 968 Coupe 6 speed (new acquisition)
Old 06-24-2011, 02:03 PM
Dawgz83948's Avatar
It only took Porsche 3 years to figure out that was a bone headed move since they rectified it on the 968.
Old 06-26-2011, 08:21 PM
Catamax944's Avatar
why not open it with the key ?? is it different from the coupe ? I always open mine with the key,the cable from the motor to the latch snapped and i never replaced it infact i also took the motor out for good when i did some weight reduction.
Catalin
'86 DD
Old 06-27-2011, 02:19 AM
Dawgz83948's Avatar
Because all the key does is turn a cam that activates a microswitch which toggles the motor to pop the trunk. There is no mechanical connection to the latch from the key cylinder.
Old 06-27-2011, 07:24 AM
From the pictures, I assume the emergency release on the 968 is behind that plastic grille in the door opening on the driver's side?
Old 06-27-2011, 08:29 AM
Dawgz83948's Avatar
On the cabriolet's only, that's what I hear. I haven't had the opportunity to look, but a good source told me this was the case.
Old 06-27-2011, 08:33 AM
