knocking in the rear??
Now another problem, when i was driving i noticed every time i accelerated and decelerated there was a big clunk. So i put the car on stands and checked to see if my cv's were good and they looked fine. drive line seemed tight. sounded like it was coming from the transmission so replaced the gear box oil and checked for any metal and there was none. So i turned the car on and put it in first and taped on the breaks and clunk every time? the clutch is fine put it in first and slammed on the breaks it died. i have no idea what it could be? anyone have any ideas or tricks i can do to diagnose the problem? its a 84 944
thank you
Old 07-17-2011, 03:51 PM
Banned
you said you touched the brakes and it made the noise, or am i understanding you wrong?
have you pulled the wheels and checked the calipers and whatnot yet?
Old 07-17-2011, 04:00 PM
yea, i put in 1st let the wheels start spinning then just started tapping on the breaks and every time i would tap on the breaks clunk it sounded like it was somewhere around my transmission. and no i have not should i?
Old 07-17-2011, 04:03 PM
Banned
definitely pull the wheels and examine the brakes, check for excessive play somewhere. has the clutch been changed from the original rubber centered one?
Old 07-17-2011, 04:05 PM
i just recently bought the car about 2 months ago and have only spent a week driving it. been in the mechanics with belts and ac and seal kit. so as far as i know about the clutch it is stock. i has 110k it has a little clicking noise but if you push the shifter down a little bit it goes away. so i was thinking that was my through out bearing. this knock though when accelerating and decelerating is loud.
Old 07-17-2011, 04:10 PM
alan6272's Avatar
Check the mounts on the trani, maybe the torque from excel decel is causing the bang.
1983 944 ,1983 V-65 magna
catalina22 sold
baja ski boat sold
my toys
Old 07-17-2011, 06:06 PM
Banned
Your rubber clutch is bad and its slamming off the pegs. When you're at speed and let go of the gas it immediately makes the noise right? And then when you get back on the gas it makes the noise too?
Rubber center clutch is bad if the above is what happens.
Old 07-17-2011, 06:11 PM
Yes, that's exactly what happens how about do you fix this does this mean I have to replace my whole clutch
Old 07-17-2011, 07:40 PM
Yeah, you have to replace the whole clutch. Mine was doing the knocking thing when coming on and off the power and it was the clutch. I found the best way to test whether it's definitely the clutch is to get under the car and take the rubber inspection panel off the bell housing on the transaxle. Then reach in and try to turn the torque tube (this is with the car not running of course!).
If it turns more than a little bit the clutch is gone.
It's a big job. I paid a shop to do mine, but after a year working on these cars I think I'd be tempted to do it myself in future.
One thing to bear in mind is that it'll make the car MUCH better to drive. I thought mine was drivable when it had the bad clutch but when I got it fixed the car was transformed.
Good luck.
Mike
1986 924S, Maraschino Red, Spax adjustable dampers, no air box lid. part way through interior swap. Lots of issues sorted, plenty more to do.
1986 924S, White, donor car, part way through disassembly.
Old 07-17-2011, 11:27 PM
ERAU944's Avatar
Send a message via AIM to ERAU944
spare tire rocking back and forth in the trunk?
i had a clutch failure and never had any clunking or weird noises. that doesn't mean your clutch isn't toast though...
oh, and how do you replace part of a clutch???
Mike - CFI, A&P Mechanic w/ I.A., Aztec driver at Island Tyme
'88 951S - zermatt silber/black - staying stock. purchased in 11-2006
'84 944 - gemini grau/tan+brown - lightly modified. purchased in 11-2001
2021 Tesla Y - to get me to work
Old 07-18-2011, 07:36 AM
Banned
You don't replace part of the clutch you do the whole thing.
Old 07-18-2011, 07:44 AM
ERAU944's Avatar
very good buddy, that was my point!
Old 07-18-2011, 08:04 AM
968 GUY's Avatar
As stated, better to replace everything at once than having to take things apart several times.
Replace hose, master and slave cyls., pressure plate, disc, flywheel at least turned, and balance the whole assy. if you can. Check release fork for wear, replace release bearing and check the clutch fork shaft for wear, replace the needle bearings that go on the end of that shaft.
There are plenty of write-ups on replacing the clutch.
87 951 all stock exc. cup II's /94 968 6-spd, lowered,17in. RUF Speedlines, M030 anti- sways/ 94 968 Tip, Cup II's, otherwise stock
Old 07-18-2011, 09:18 AM
Garage Helper
Cocacolakidd's Avatar
Send a message via Yahoo to Cocacolakidd
While you are in there of course you will be replacing the throwout bearing, but also replace the pilot bearing in the flywheel. Absolutely check the throwout fork for cracks and wear, replace if necessary (The throwout fork has a reputation for breaking, cracking at the arms). Replace the throwout shaft bearings as necessary (Not to expensive parts to do while there, and good insurance).
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now).
UAV-M1 (Urban Assault Vehicle - Model 1)
Bless the lowered, and pass the nitromethane.
Pedal to the metal till you see the gates of hell then brake
NLA - No longer available is a four letter word
Old 07-18-2011, 04:09 PM
thank you. i started today with my buddy. I got it up and removed the exhaust and now working shifter. When i buy a new clutch wont it come with most of that stuff? Any suggestions on where and what clutch to buy with this stuff?
Old 07-18-2011, 08:04 PM
Banned
I bought the Sachs clutch disc off Amazon and replaces absolutely nothing else. Some people will cry foul at this, it is your judgement and yours alone on what NEEDS to be replaced. I greased everything I could reach with fresh molybdenum grease. You can even grease the throwout bearing if you feel like sitting there and spinning it in through the crack where the halves meet.
Again this is a judgement and a budget call. Mine was budget influenced.
Old 07-19-2011, 08:40 AM
