Porsche Crest Hard Starting First Time only
Hi,
I have a 1995 Porsche 968 with 115K on it.
After the car has been sitting for a while, the first time I try to start it, but occasionally it doesn't start. Something like loosing power. If I then turn it off, I can immediately start it without any problems.
Recently done Tune-up(Cable, Spark plugs, Ignition Coin, Rotor, Oil, Fuel Filter, Fuel Pump, Oxygen Sensor and Water Sensor)
This is the video: ‪1995 Porsche 968.MP4‬‏ - YouTube
Please, help me. Thanks.
Old 07-31-2011, 12:58 AM
I have the same issue with a 968. Mine also takes two tries to start when cold, like it cant get fuel, and inbetween 2k and 3k studders like crazy. I read in one post the studdering under load was faulty O2 sensor. Im thinking they are related.
Anyone else have ideas on this?
I like them I drive them
Old 10-12-2011, 02:41 PM
Proprietoristicly Refined
John_AZ's Avatar
Hard starts can be caused by fuel problems.
Check the FPR --Pull the vacuum line and check for dampness/fuel. Even if no fuel is noticed, it could be bad.
If you have 115K miles, it may be time to send the injectors to WitchHunter Performance - Injector Cleaning & Flow Testing Services or similar or buy new. You may have a slight leak and this will depressurize the fuel lines.
At least pull and reseal. There are a few DIY cleaning suggestions on the net.
You could pull the injectors, get plastic baggies and put a piece of brown paper bag in each baggie. Wrap a baggie around each injector---in the morning, the paper will have a mark if the injector leaks. Have new seals lined up.
Maybe try a couple of cans of Chevron PREMIUM fuel injector cleaner and premium gas for a couple of tanks.
There are voltage checks for the O2 sensor---I am not sure why the studdering is related to the O2 sensor. The DME engine temp sensor is more the problem.
Just ideas
John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 10-12-2011, 05:55 PM
