944 Problems
So a couple of days ago i posted about how my 1984 944 overheated and the radiator hose to the reserve tank ruptured. Today i replaced the hose and the oil. I realized that the oil level was extremely low so i replenished that. So I starting it up today and I had even more issues! First off the oil pressure gauge is a zero and it would rev up to 3000 RPM is a few seconds after starting. What the heck is going on?
Old 08-10-2011, 10:00 PM
...is the gauge working?
Old 08-10-2011, 10:54 PM
Proprietoristicly Refined
John_AZ's Avatar
I see you got your Porsche.
Looking to buy a 944
and then the break down:
1984 944 Over Heating Issues
v2rocket_aka944 could be right-usually so.
Was the oil level extremely low when you bought the 944. Did you check?
To loose a quart or so of oil----unsure of how much volume "extremely low" means....
is not good.
Get some tools at Harbor Freight, compression tester and leak-down tester about $100 or less and do some tests.
Compression-leakdown test
Are your plugs oily? What color is your exhaust smoke?
Did you have an oily film in the coolant reservoir that looked like brown milkshake?
The compression/leak down test will confirm if the engine is damaged--heat warped head, rings, head gasket.
Remove the DME/fuel pump relay before testing. You do not want the injectors pushing gas in the cylinders.
GL
John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 08-11-2011, 08:24 AM
