-   -   M030 sway bracket (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/625103-m030-sway-bracket.html)
c5pilot 08-16-2011 10:03 PM
M030 sway bracket
I am trying to install a M030 rear sway on an 83 and the busking brackets seem too shallow for the bolts to reach. Are there different brackets ?
Rasta Monsta 08-16-2011 10:10 PM
Rear brackets should be the same. Did you get the bushings that go with the bar?
c5pilot 08-17-2011 01:22 PM
Yes I have the proper bushings for the larger bar. sorry it was late in the night and I must have been just lazy. Today I clamped the bracket down with some Channel locks and got the bolts on just fine.
walkerhiboost 08-17-2011 01:26 PM
Spray a dab of WD40 or other lubricant to ease the installation. I don't know if these 944s have sqeaky sways, but I always wrap the bar with teflon tape before placing it into a bushing.
Rasta Monsta 08-20-2011 01:20 PM
I use white lithium lube on rubber. . .WD40 could degrade the bushing.
