M030 sway bracket
I am trying to install a M030 rear sway on an 83 and the busking brackets seem too shallow for the bolts to reach. Are there different brackets ?
Old 08-16-2011, 10:03 PM
Toofah King Bad
Rasta Monsta's Avatar
Rear brackets should be the same. Did you get the bushings that go with the bar?
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 08-16-2011, 10:10 PM
Yes I have the proper bushings for the larger bar. sorry it was late in the night and I must have been just lazy. Today I clamped the bracket down with some Channel locks and got the bolts on just fine.
Old 08-17-2011, 01:22 PM
Spray a dab of WD40 or other lubricant to ease the installation. I don't know if these 944s have sqeaky sways, but I always wrap the bar with teflon tape before placing it into a bushing.
Old 08-17-2011, 01:26 PM
Toofah King Bad
I use white lithium lube on rubber. . .WD40 could degrade the bushing.
Old 08-20-2011, 01:20 PM
