Roger Hall's Avatar
Need Tech Advise
my 81 924 started making this loud shuddering noise durring hard cornering it scared the **** out of me the first time i thought it was the cv joints i removed the cv joints today and they are worn but i dont think they are worn enough to cause that noise i hope i am wrong though i will order the parts and some redline gear oil today
but here is the question do i need to look at the transmission as the cause in the haynes manual under the troubleshooting section it says if you hear a clunking noise while cornering check the planatry gear for wear is this as bad as it sounds i thought these transmissions were bulletproof
Roger Hall
81 924 N/A
Some people are like Slinkies. Not really good for anything, but you
still can't help but smile when you see one tumble down the stairs.
Old 03-16-2002, 02:51 PM
Porsche Crest
Have you thought about re-packing the bearings or has is been done recently??? Just a thought,but I've had some bearings do the same in other cars but not in a 944. Luck...Jim H
Jim H.
85.5 944(61k)Saphire/black
87 951(28k)Nautic- green/beige
02 A-6 quatro green/beige
rennlist-PCA
Old 03-16-2002, 03:57 PM
Roger Hall's Avatar
the outer race and the bering cage show wear two of the outer races have groves in them from the ball berrings after 100k i figure i will replace them the wear just did not seem to allow for enough play to cause the noise
Roger Hall
81 924 N/A
Old 03-16-2002, 04:44 PM
