-   -   Temp. Readings - Comments? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/627587-temp-readings-comments.html)
OK-944 09-01-2011 03:28 AM
I took my 85.5 a bit further yesterday...enough to get things really warmed up (car seems very well behaved), and also borrowed a laser temp. gun, and from this got the following results:
Top of Hood (over exhaust location): 144 f.
Valve Cover: 186 to 202 f.
Max Temps. for Headers: 600 to 650 f.
Underside of fuel line over headers: appx. 150 f.
Exhaust just before Cat: 250f.
Cat: 360f. towards front, 260f. towards back
Just after Cat: 160 f.
Rear Muffler: 260 near front, 200 near rear.
I'd welcome comments on the above. Thanks!
John_AZ 09-01-2011 06:06 AM
Interesting.
Do you remember where the coolant temperature guage was at?
http://forums.pelicanparts.com/uploa...1314882273.jpg
From-- http://www.clarks-garage.com/pdf-manual/elect-19.pdf
John
vdubr928 09-01-2011 08:03 AM
Looking normal or low to me. What was the temp gauge at?
Rasta Monsta 09-01-2011 08:03 AM
Only one of those temps is mildly relevant. . .the cam box, which seems fine to me.
vdubr928 09-01-2011 08:28 AM
What I should have said. Interesting reading though. Wonder what the turbine housing on our 31s. would read after a good run. Lol
ernie9944 09-01-2011 08:45 AM
Lol you don't want to know:D
Rasta Monsta 09-01-2011 09:19 AM
Four digits, to be sure.
OK-944 09-01-2011 10:59 AM
Temp. guage just a little above the first (80 C) hatch mark most of the time...and when sitting at idle for a couple of minutes it goes up to just about the exact middle of the scale - maybe a little above this but so far not to the second (100 C) hatch mark.
Sometimes I think that the thermostat may not be fully seating on its lower gasket - but basically the car seems fine.
On the online forum someone remarked that my header temps. sounded just a bit high, indicating a lean running condition...so I may check into this.
vdubr928 09-01-2011 12:08 PM
I don't think so and it should be a touch leaner at idle. Imho
