924 turbo - smoking
hi
i have just bought a 1981 924 turbo (series 2) which blows out light blue smoke above 3000rpm ! I have removed the plugs and all 4 are black and oily, how do I tell if it's the turbo, the ring, bores or the head/valves ? or could it be something else ? |
Compression and leakdown. But sounds like turbo.
82 928 s3&1/2 5 Speed LSD conversion 87 944 N/A 5 Speed (Under Construction) 81 931 (maybe for sale, well their all for sale lol) Always looking for a good deal. Hello, my name is Carl and im a Poschaholic |
Yeah, what he said - compression and leakdown.
Noting that the boost comes on around 3000rpm, it would seem you have a boost-related oiling problem. Given that it appears to be bringing oil into the combustion chamber... the oil should be coming in in the intake tract. Very likely seals leaking in the turbo, but do the leakdown first to make sure the basics are good. Then to line up a turbo rebuilder; it's not easy to remove the turbo with the engine in, but will save a lot of money if you can just send out the turbo. There's lots of guys in the UK on the 924board.org - one or more can probably recommend a turbo rebuilder. These cars do also tend to have the valve seals harden up and leak with age/heat... but those are different symptoms... Congrats on the purchase!
Vaughan Scott http://www.vaughanscott.com http://www.924.org |
All Spooled Up
Without water cooling (and turbo-timer w/electric WP), those turbos run real hot. That means that the seals will have a relatively short lifespan. The factory learned a lot about this issue, from that particular model. This is evidenced in the next turbo model of the FF (front four) series in 1986. They definately switched-up and went all-out on turbo cooling there. And they weren't concerned about the complexities involved in making that happen.
That does seem to be their M.O. when it comes to most issues though. They aren't afraid to use complexity as a means of solving issues. But that may have been what killed the series. Do hear "over-engineered" (especially the FFT)? With complexity comes not only higher initial cost, but also more things to go wrong, meaning more repairs, which also cost more because they take longer due to more OTHER things needing to be removed. Last edited by wild man; 09-12-2011 at 05:45 AM.. |
Toofah King Bad
Gotta disagree with the above. With proper cooldown, the seals last just fine. The 951 setup was employed to avoid a common operator error. . .shutting down red hot.
» 1987 924S Turbo - Got Boost? « "DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc |
Thanks guys
I have a compression tester but will have to find someone to carry out a leak down test. So if i understand this right, the turbo is forcing oil (from it's own lubrication system- the feed and return pipes ?) through the intake and into the combustion chamber ? if so would I be able to trace and see the oil path to confirm this ? |
Toofah King Bad
The turbo CAN spit oil into the intake, and into the exhaust. One clue in your case is your fouled plugs.
These cars also tend to break rings, and if you have excessive blowby, the turbo seals won't work regardless of their true condition.
It doesnt look good for your turbo but its worth doing the compression and leakdiwn test.
