first child 84 944
DME Found missing grd no start
Hello to all again, ok after all tests that were done i have found the ground on the dme that closes the loop for grounding fuel pump that energizes the dme relay. In turn also controls ground loop for inj not grounding. So here is the question> Anypne know where to find on the dme board a lable diagram for it? I need a diagram of inside of dme computer to fix the board. Thank you for any help as well as all the help provided.
Sure, schematics are on Clarks Garage and using the search feature here will lead to pics, PCB layout and more info.
If it aint blown, it sucks! World`s quickest 924 2L slushbox. |
first child 84 944
ah thankyou so much when scoped from both speed and ref sen it for sure wasnt reading due to a belived faulty ground from dme i think thanks again so much
Proprietoristicly Refined
Just a suggestion before you try to rebuild the DME .
A few members have successfully resoldered the DME. Early DME repair write-up with pics. - Rennlist Discussion Forums OR DME Repaired w/pics - Rennlist Discussion Forums You are determined. GL John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo) |
Sounds like you know enough about electronics to at least tackle this. Kudos, most other guys would simply be chasing a second hand DME.
Obviously check all connections and for dry joints on connector and switching transistor which is as far back as I think you will need to chase it. If the transistor proves faulty there are more modern substitutes. Here is the 951 schematic which is easier to read, output stage is similar. Good luck.
So if I can offer another DME OEM worksheet with values. The Porsche 944 Motronic DME Also here is a flow chart of troubleshooting that may be helpful ![]() GL John
first child 84 944
Hey guys, wow i cant belive i have recived this much help and info, lol cant say it enuff thankyou. Yes i belive i have narrowed it down to pin 19-20 on dme -20 on the transistor. I am keeping all crossed, fingers toes, legs, and anything else i can find lol thanks again i will give it run again tonight. Will try and get some pics posted
first child 84 944
Hello again, just wondering if specs on dme testing are the same for 84 vs 85 1/2 thankyou
Short on time to give absolute answer, sorry.
FR Wilk may have the answer here or on his site. DME (ECU) GL John
