-   -   Rear window border and windowseal.. some questions.. (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/629699-rear-window-border-windowseal-some-questions.html)
Joakim 09-14-2011 04:43 AM
is there any way to fix the border of rear window?
the black plastic covering is pealing off, and the "tape" inside the car is is loosing its glue
http://forums.pelicanparts.com/uploa...1315998677.jpg
and actually where should the window seal hit on rear window?
My oppinion is that it should hit the metal that is around the window.. but it is not even close..
like that, that the rear window is too big for sitting there
it is not the problem.. nothing is leaking in but when lookin closely it is actually quite a "ugly"
http://forums.pelicanparts.com/uploa...1316000452.jpg
http://forums.pelicanparts.com/uploa...1316000467.jpg
http://forums.pelicanparts.com/uploa...1316000478.jpg
carsonmx114 09-14-2011 05:04 AM
go to a tint shop and they can put some semi-flat tape on the outside that will look nice and hold up to the elements
Joakim 09-14-2011 05:06 AM
has anyone tinted theres rear windows?
if you have can i see pictures. :)
Techno Duck 09-14-2011 05:43 AM
The rear hatch is no joke considered to be one ofthe hardest windowsto tint in the entire auto tint industry. I bet atleast one place you inquire to about tinting it will laugh or ask if your joking. Finding a place that can also do it in less than 3 pieces will be a challenge also!
carsonmx114 09-14-2011 06:26 AM
I was a professional window tinter for ten years, I was doing it when we started shrinking the tint to match the curve of the glass. My cousin still does it and in my opinion is one of the best. He tinted my 951 a couple of years ago and still gives me hell about it! The third brake light helps take up some of the tension but I'm thinking he did mine in 3 pieces as well. It's cut on the defrost lines though so it looks fine.
Joakim 09-14-2011 08:37 AM
well I am afraid that black tinted windows is not nice on white car? or am I wrong?
and I can put my 924 on museum registration 2012..
does the tinted windows effect that?
carsonmx114 09-14-2011 10:35 AM
I'd go with 35%. Anything darker is illegal here anyway. I agree on the blacked out windows, looks a bit gangster...
Joakim 09-14-2011 10:46 AM
How about the window border? do I peal all black plastic off, or just get some fix there?
carsonmx114 09-14-2011 03:50 PM
If the border is like mine it's on the inside of the glass. I'd peel it if it's loose so the pieces don't get under your tint then put the tape back on the outside.
