-   -   Any special considerations for replacing the DME relay? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/633575-any-special-considerations-replacing-dme-relay.html)
monomoy4 10-07-2011 02:32 PM
My 924S cranks and cranks but won't turn over. The fuel pump/filter are new and work. Plugs are new but I'm checking spark this evening regardless. There's no jump or movement of the the TACH on crank - People seem to point to crank position and speed sensor failures here.
However, would there be TACH movement if the DME is bad?? Seeing how removing the sensors seems like a very difficult job b/c there doesn't seem to be any room to work with tools, I figured maybe I'd try the "easier" job of replacing the DME instead and hope the sensors are actually fine.
Sorry for the long lead up, but I'm assuming I need to unscrew the lower fuse holder (1-9) to get to the #2 fuel pump relay? or is there some trick to getting to it without having to unscrew a bunch of stuff. It just seems like such a hassle to remove that relay, given the tight space and awkward position I have to get into to reach the relays.
DME Relais 944.615.227.00
North Coast Cab 10-07-2011 03:27 PM
The dme relay is in the fuse box under the hood on the drivers side. It is a 10 second swap.
The sensors are very accessible. You need a 10mm with long extension and may need to push some wiring out of the way. Do them one at a time and you may want to unconnected and reconnect them before swapping to make sure they are seated.
Jrboulder 10-07-2011 04:05 PM
Nope. The relays are under the dash on an early car.
To the OP: I've been able to just pull the DME relay out.
Jackson
SolReaver 10-07-2011 07:09 PM
DME duh
Very simple.
First of all purchase a NEW DME relay. You need a back up anyway.
Second LOCATE your DME relay. Most folks THINK they know where it is. to be absolutely sure ohm out the power wire to the FP back to the DME terminal and for gods sake check the ground and power TO the terminals.
Now, rather than being a parts replacing monkey. Let's get technical. Does your fuel pump get power when you crank the car? Have you tried jumping the DME and what is the result?
When you say the fuel pump is fine...how do you know that?
Check the sensor connector before replacing the sensors. Sensor replacement is a PITA at best. Don't do it before figuring out that they are truly bad and a SIMPLE resistance test is all that is required.
John_AZ 10-08-2011 06:10 AM
Originally Posted by SolReaver (Post 6298604)
Very simple.
Now, rather than being a parts replacing monkey , Let's get technical.
Sol,
I am getting used to your patient approach in answering members questions.
:D
Or maybe you're working off some frustration after getting home from work.
Your points are correct!!
OP (original poster)
Remove the sensors from the sensor bracket. IF YOU CAN with out damaging the sensors.
Check the sensors, check the connectors for corrosion, check the sensor wires for cracks and bad joints.
BMW Bosch sensors are only $60 or so, half the cost of OEM Bosch Porsche sensors. Use the interchange.
Clean the flywheel studs of grease. Set the sensor gap.
Speed and Reference Sensors - Checking, Replacement, and Adjustment
GL
John
SolReaver 10-08-2011 09:14 AM
Too experienced
John: "monkeys" is a term of endearment !! these cute little creatures bring me lots of business.
I actually have great respect for the determined individual who champions on to fix their own car AND I have respect for those who would rather hand it off to a professional. With any luck, the professional will be professional...
There is a problem solving approach that I actually call "parts replacing monkey"
When something doesn't work...just start replacing parts...eventually you will replace everything and have a brand new running car.....:rolleyes:
IF you choose the right part...you win! it is kinda like Vegas.;)
On the day when Alzheimers takes hold and all the hard living catches up to my feeble brain... I will abandon logic and analysis and just start replacing parts willy nilly. As a mechanic I can make a great markup on each part that doesn't need replacing and shrug my shoulders when it still doesn't run. I will begin practicing my mouth breathing and vacant stare in the mirror so that I can make a convincing performance that I really can't figure it out.:confused:
But yea, I know I have all the tact of a marine drill Sergeant. Glad to see the folks around here know better than to take me seriously.
Now if the OP can get back to us with a status report, between the bunch of us we MIGHT figure it out. I was thinking we replace the Fuel pump, then the wrong relay, the headlights, the ignition switch, the battery, alternator,:rolleyes::D
Timmay! 10-08-2011 06:30 PM
Momomoy,
The DME/fuel pump relay is quite difficult to remove because there's a relay on either side of it, plus it's up behind the aux fuse block.
BTW, cranking IS turning over. It just won't start.
Have someone put their hand on the fuel pump while you're cranking the engine over. Your 924S has the pump in the open so this is easy. If it vibrates, your DME relay is probably good. The relay is always the first suspect in these cars. Carry a spare.
That relay does two things. It powers up the fuel pump and the DME , or computer. If you suspect it, the first thing you do is bang upward on the relay board with your hand while starting the car. If it fires up, replace the relay.
Do that by:
disconnecting the battery
remove 2 phillips screws holding aux fuse panel and swing it out of the way.
Fan relay is on the top left. DME relay is the tall one next to it. Check orientation of the relay before pulling it. It has 7 pins, several of which are smaller.
Guest765 10-08-2011 06:41 PM
Timmay you have to be trying pretty hard to put it in the wrong way. The pins are set up so that it will only fit one way.
Timmay! 10-08-2011 07:06 PM
True, but it's dark and awkward and you have to push pretty hard even when it's oriented correctly.
Kinda like having sex for the first time? :)
SolReaver 10-08-2011 07:53 PM
young love....
Yea, and just like sex for the first time you are all by yourself and have no idea what you are doing!
SolReaver 10-08-2011 08:08 PM
SAD but true
OK folks. Yes the DME relay is suspect in a no start condition, but before we go too far here we should really wait for the OP to get back to us with the facts. We want to know if the FP is getting power when he cranks the car. This can be determined by placing your hand on the pump, located passenger side just forward of the gas tank. When the car is cranked (by an assistant unless you have really long arms) the relay will give power to the pump and the pump will buzz with happiness. you can also check this happiness by putting a test light or VM on the FP and checking that there is 12v or so on cranking. A THIRD way is to crack the fuel line at the rail and put something to catch the gas when it pumps out.
NEXT.... IF the FP is not happy...you would want to "jump" the relay. the forum is resplendent with examples of fancy jumper things. Paper clips work in a pinch as well. IF THAT doesn't work then you try jumping power directly to the FP.
Above all...We are dealing with a 924S here...The DME relay is NOT in the same place as a 944 and extra caution is urged in the identification and confirmation of this unit. SEVERAL apparently intelligent people have mistakenly replaced the wrong relay. See previous post to confirm you indeed have the correct relay. I have a 924S as my daily driver. Trust me in that it is worth the 2 min it takes to be sure. I paint my DME a bright color and have 2 spares.
OK Monomoy4...What is the verdict?
monomoy4 10-09-2011 12:22 AM
Yeah, the relays are unfortunately under the dash here....not the hood.
monomoy4 10-09-2011 12:28 AM
Very simple.
Located the DME relay under the driver dash area. Fuel pump/filter are newly installed this summer, but I did have my wife crank the engine while I felt the fuel pump for vibration/action....it worked. I haven't tried jumping the DME b/c I'm not comfortable, yet, with what I've read so far in Clark's Garage. Figured I'd rather just replace it entirely for now and test later.
Yeah...those sensors do seem to be a PITA which is why I'm going the DME route first. I've got a test for the connectors - but how the heck do I get the connector to separate? I've got limited patience here as I'm fixing issues on my 79 CJ as well...
monomoy4 10-09-2011 12:30 AM
Originally Posted by John_AZ (Post 6299090)
Sol,
GL
John
You say use the "interchange" - what's that??
monomoy4 10-09-2011 12:33 AM
Heh - yeah sorry on the delay on response. Been out working in the yard nonstop - not often we get killer weather here in STL
monomoy4 10-09-2011 12:36 AM
Originally Posted by Timmay! (Post 6300079)
Momomoy,
Do that by:
Thanks Timmay! Yeah, my mechanic mentioned holding the pump while cranking...and thanks on the crank vs turn over = same. So what you're saying is that since the fuel pump works, the DME should be fine??
monomoy4 10-09-2011 12:43 AM
Thanks SolReaver - and again sorry to ALL for the delay in response. I have tested the fuel pump...it works. Unfortunately haven't gotten around to testing for spark, yet.
To my earlier question about the TACH jump - does the TACH fail to jump on crank only when the sensors fail? or would it fail to jump on DME failure, too??
SolReaver 10-09-2011 01:17 AM
Tactical
Sorry Monomoy, I never could keep the whole tach thing bouncing stuff straight.
OK, soo...the fuel pump energizes., we don't know if we have signal and we don't know if we have spark...Great.
yea, check for spark. Yaknow an industrious little fellow would have checked spark by now.
If you have a "noid" now would be a good time to use it.
Please don't ask me what a "noid" is...I would just loose faith in you.
With the ignition on check for voltage at the hot side of the coil.
Sensor connectors are taken apart very carefully and yes, they stink. Be aware the plastic that they are made out of has become brittle with age and if you are not uber careful it will all shatter.
When you have the connectors apart measure the resistance of the Sensors as Clarks recommends.
If you have spark...try a shot of starting fluid and see if she kicks.
Getting bored here....
John_AZ 10-09-2011 05:50 AM
A sensor from a 1988 BMW 535i will work in place of the OEM Porsche 944 reference sensor--thus interchange and is cheaper.
The wire is longer and Porsche prefers the longer wire to prevent kinking of the wire in a TSB.
Do a search for others that will work on the forums.
I prefer to use sensors with the silver can at the bottom instead of an all plastic sensor. A little more protection for the sensor.
Pelican has both.
GL
John
CatsEyes 10-09-2011 06:40 AM
If it does indeed turn out to be the sensors (did you test the connectors yet, by the way?) I'd recommend reading up here before doing the change. It's not so hard, but a bit fussy.
Especially note the advice to cover up the small hole at the top of the clutch bellhousing where you look for engine TDC. Or just stuff a cloth in the opening. I forgot and had my heart in my mouth for a good couple of hours before I finally located the speed sensor bolt, hiding out of sight a few inches away...
Timmay! 10-09-2011 10:02 AM
Mono,
sounds like the relay is ok.
John_AZ,
That tip for using the BMW flywheel sensors is a good one. Saves $. Good on you. I had forgotten about that because we have so many used spares.
Solreaver ???
The 924S has the DME relay in same exact position as an early 944.
I doubt Joe average 944 owner has a noid? I'd check for spark at the end of the line- at the spark plug. Remove a plug and set it on top of the engine so that it can ground out and show a spark. That will verify your reference sensor, coil, distributor cap and rotor, plug wire,etc are all good and in one fell swoop.
monomoy4 10-09-2011 07:16 PM
Pelican has both.
GL
John
Ah got it - figured that may be what you meant - thanks for the advice. I'll be sure to keep that in mind
monomoy4 10-09-2011 07:29 PM
Good advice - much appreciated. Heh, yeah Heard of the noid but haven't used it. I did pick up an ignition tester this afternoon. in the learning stages here regarding diagnostics...
84 944 oneowner 10-09-2011 07:35 PM
oh man i feel your pain and just fixed mine 944, Post one of mant problems, maybe not. Turns out my tach isnt even working, Replace both sensors speed and ref sensors, without both working you will get a no start 100%. hope it helps.
monomoy4 10-09-2011 07:38 PM
Haven't tested the connectors, yet. I'm not sure what I was doing wrong, but I couldnt get the connectors to separate... I'll try again tomorrow night when I can work on the car again.
And thanks on note re covering the hole - yeah, I recall that advice and was sure remember!
monomoy4 10-09-2011 07:53 PM
Originally Posted by Timmay! (Post 6300819)
Mono,
John_AZ,
Solreaver ???
Awesome Timmay - thanks. Yeah - I think that ignition tester i bought yesterday will do what you're saying. I got the one that clamps on the plug with an adjustable gap. As you mention, this test was suggested by the guy who's worked on the car before. I can't work on this thing until tomorrow after work. DME i ordered will also arrive should I Need it. Tomorrow - Will be checking for spark, hopefully also be checking sensors if I can just get the connectors to separate...
All --Much appreciated help!!
CatsEyes 10-10-2011 08:35 PM
Not sure I follow you. I meant the electrical connectors, which are connected only with a gentle push and one of those little metal clips, like an over-sized staple. Shouldn't be any trouble at all. A flat-head screwdriver should get the clips off.
You test the sensors at the connectors with a multimeter, as described at Clarks Garage:
http://www.clarks-garage.com/pdf-manual/ign-02.pdf
monomoy4 10-11-2011 07:53 AM
Ah, okay - I figured those clips had something to do with pulling apart the connectors, but quite honestly, I've already thrown a ton of money into the car and was afraid I'd mess something up further. I'm glad to hear it's not a big deal.
When I test with the multimeter, should ignition key be turned to on? engine cranking?
monomoy4 10-17-2011 09:33 PM
Just a quick update, anyone still listening? - Haven't had much time to work on this lately.
1) Tested for spark - none at any of the 4 wires (recall, there is fuel, though...or at least, pump is working...pump, filter, and injectors were recently replaced)
2) Also tested DME relay - replaced with new one that I had ordered as a spare...no change...replaced original after cleaning metal connections - the relay connectors seemed a bit - darkened?? with an odd burnt smell...not sure if this mattered since the new relay didn't work either.
3) Disconnected the speed and reference connectors...in great condition, physically. Tested terminals with multi-meter...With ignition turned on and using Clark's specs ("Sensor Resistance Checks"), it appears the the BG sensor (reference) was reading 1024 ohms on 25-26 terminals and a >1 M reading on 25-78 terminals. The DG sensor (speed) did not show response on the multimeter...at least not in the way I saw with the reference sensor.
Have not tested ignition coil. plug wires were not replaced with recent change of plugs, cap/rotor. The wires appear to be in okay condition and were not recommended for replacement by the mechanic. Recall, also, that there is no jump on TACH on crank.
SolReaver 10-18-2011 06:40 AM
Is there anybody...out there.
Just noid if you can hear me...
Is there anyone on the home page?
No spark! boo hoo!
DG not showing response on the multi meter? like open field? Short?
Yea, if it is out of spec...looking like the sensor. unless power isn't getting to the coil or a dozen other things. Oh well.
I DID ask about power to the positive side of the coil and if you had tried a noid we could know if the injectors were firing..... BTW a Bosh noid is like 5 bucks off of fleabay. buy a couple and give them as stocking suffers to your Porsche friends along with spare DME's .
Hmmm...welll if the DG is out of spec...you know what to do. Hit it with penetrating oil to loosen hings up and get to it when you have a chance.
Timmay! 10-18-2011 08:47 AM
Mono,
I'm still listening..........busy, but listening.
Swap out that sensor with a used one.
Remember both sensors are the same part. Make sure they are connected right at the wiring harness tho. If the connectors break, make a bridle for them with zip ties.
Get together with other 944/924S owners in your area to pool parts/resources.
Keep working on it.
:) These are cool old cars.......
monomoy4 10-18-2011 07:19 PM
I DID ask about power to the positive side of the coil and if you had tried a noid we could know if the injectors were firing..... .
Okay, okay - geesh, I'll buy a noid. I know I need one anyway... What do you think about the universal ones?...or should I focus on one that fits the 944 engine specifically?
monomoy4 10-18-2011 07:24 PM
Originally Posted by Timmay! (Post 6317245)
Mono,
Thanks Timmay! I'll take yours and SolReavers advice and get on that as soon as possible. I agree, this is a great old car...I hate seeing it sit in my garage unused.
Timmay! 10-19-2011 07:27 AM
The only noid I have is one that fits into the injectors plug of the wiring harness. About the size of a quarter.
michael944s900s 10-19-2011 07:32 AM
put ur or have sumone finger on the relay if it clicks at key entry n start its bad if it clicks once its good
michael944s900s 10-19-2011 07:34 AM
http://clarks-garage.com/shop-manual/repair-procedure-index3.htm#foxtrot
Clark's Garage Shop Manual Index
Timmay! 10-19-2011 12:08 PM
MONO,
My noid says OTC 7602 GM PFI. The spacing of the contacts matches a 944 injector plug.
michael944s900s 10-19-2011 01:19 PM
did u check the ignition switch
monomoy4 10-22-2011 09:43 PM
Coil good, have not checked ignition switch
Recap....dme relay/fuse good, fuel filter/pump good, injectors good, have fuel, have spark, reference sensor good, speed sensor appears to be bad
Just got 2 sensors in mail yesterday, and I'm ready to replace the speed sensor which seems to be the bad one according to my multimeter check....but even with a socket 10" extension, I can't reach the retaining bolt...let alone get my arm/hand down in the space to effectively guide the removal/replacement of the sensor. the sensors are located so close to the firewall and under other engine components that I'm unsure how I could access the retaining bolt without removing a whole lot of stuff to get to it. what gives? is there some unique difference between the 944 and 924S engine compartment design that makes this replacement more difficult on the 924S side? Aside from disconnecting the connector, what needs to be done to get this sensor out??
Originally Posted by Timmay! (Post 6319652)
MONO,
Thanks Timmay! appreciate the info
